Question about Saeco Gran Crema 2-Cup Espresso Machine - Black
The machine lost it's prine and now we can't seem to get it to take a prime. We've tried several times and it won't take anymore water but when we attempt to make a cup, it won't push any water through. We tried turning it upside down, and while upside down, it would push water through the filter, but then when we turned it right side up, it wouldn't work again.
    President:
  • 1,618 Answers
For that one you might have to take the water hose that leads into the pump fill it with water and hold it up while running the hot water cycle to prime the pump.
Posted on Nov 15, 2009
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
It's says it's brewing and the water will go into the "warming chamber", but then it like freezes and the Keurig won't do anything. It just continues to say brewing, but nothing...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101 ./.,.,
Aug 13, 2011 | Keurig Platinum B70 Coffee Maker
The display keeps flashing Not Ready. Water is full. I've unplugged the machine and plugged it back in. Why won't it get ready?
heatman101
May 29, 2011 | Keurig B70 Coffee Maker
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
Airless sprayer will not prime Model AL230502LX
Check for a plunger on the bottom of the machine. Pump it several times and try to prime with water. Also, if there is difficulty priming after trying the plunger, switch on in prime, and cycle to paint, back to prime,paint,prime. After several tries, leave it in prime with the pickup tube in water, and pump the plunger again. If this doesn't help, disconnect the hose fron the pump and try again. If you're getting water now, the issue is down the hose, or at the roller/gun.
Hope this helps! --W/D--
Jul 12, 2009 | Campbell Hausfeld Airless Spray Guns &...
Baby gaggia wont pump
The pump may only have lost its prime. To prime the pump:
Fill an ear syringe (available at most pharmacies) with water. Insert the business end of the syringe securely in the tube that normally takes up water from the reservoir. As you squeeze the syringe bulb, flip the brew switch on. If you see movement of water in the tube, and hear a change in the sound the pump is making, flip the brew switch off, remove the syringe, and put the tube back in the filled reservoir. Now flip the brew switch on, and see if the pump can draw water on its own. Repeat several times if necessary. If the pump still won't pull water, then it must be replaced.
www.espressosolamente.com
Apr 21, 2008 | Gaggia Baby Espresso Machine
Saeco Gran Crema 2-Cup Espresso Machine - Black Logo
145 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
