Question about Westinghouse LCM-19v5 Monitor
I have a Westinghouse LCM-19v5 monitor. When I start the computer, after the startup screens, the monitor goes black and I get a red bar with the message "Out of Range." I am in safe mode right now, the only way that I could get the screen up.
  • 78 Answers
In the safe mode you have to change the resoulution and the frequency to 60 hz you can get it by fright click on the screen and then choose properties and then choose settings and adjust the resolution to 1280 to 800 and then choose advanced then choose monitor then choose the frecuancy to 60 hz ok and apply ok and insa every thing will be ok conntact me for more if you still haveing the same problem
Posted on Nov 15, 2009
My Westinghouse LCM 19v5 will not powerup
Look for bad caps with bulging tops, similar to the 19" version as shown here:
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/Westinghouse%20LCM-20V5/
Make sure to use correct type caps for switching power supply.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
My monitor Westinghouse Mod# LCM-19v5
The most common thing that causes no power or a blinking power light and no picture is a failure of the power supply board. The board can be repaired and the monitor will be as good as new. To repair the board you just need to replace a few parts called capacitors. Here is a link to repair information on the Westinghouse LCM-19V5
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-19v5/
I hope this helps, if so please rate my solution.
I picked up a used westinghouse monitor, LCM-19v5, and it works fine as a plug and play. I was wondering if there might be a driver for it to download that might make it even more crisp and sharp.
This monitor only uses plug and play drivers and unfortunately there does not appear to be much support for them on Westinhouse's support site.
Jul 10, 2011 | Westinghouse LCM-19v5 Monitor
Installed new 27-D01567 power supply unit in my 19" monitor L1975nw. have green light but black screen. whats next?
Is the board brand new or used? You will need to verify the voltage (12~18vdc) feeding the inverter circuits, there is also a surface mounted fuse.
Try reading here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/#step1
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Nov 05, 2010 | Westinghouse LCM-19v5 Monitor
Does not power up freind thinks it's a blown capacitor
Yes, it can be that and other components.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE (LCM-20V5 may be thesame chssis as yours) and monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Westinghouse LCM-19v5 Monitor
Screen goes black after fraction of a second
More likely to be bad capacitors in the power supply, see LCM-20V5 (almost the same chassis as used in LCM-19V5) example: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Mar 15, 2010 | Westinghouse LCM-19v5 Monitor
Monitor works for a fraction of a second
See article written by sillybit (me) for the Westinghouse 19v5. My 20v5 had bad caps in the power supply - it did the exact same thing as yours. $8 worth of parts from radioshack and an hour or two is all mine needed.
Aug 01, 2008 | Westinghouse LCM-19v5 Monitor
Westinghouse LCM-19v5 Monitor Logo
328 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
