Question about Carrier Cycling
I tried all combinations twice, I have pried open the mecahnism as far as I can see and there is no distinguishing mark on the rotating **** - I plan on ripping the mechnism out and maybe it will at least close. I can jack the handle open with force and close it with force but I would prefer no locking mechanism to this rubbish.
    Problem Solver:
  • 17 Answers
Get a bmx **** wit it wouldnt happen
Posted on Nov 15, 2009
HOW TO CALIBRATE A HILTI PRI 2
To check calibration, take it into a hilti center. they'll check it for you. Otherwise, set it on a countertop or table. Mark its level at a distance of 15 feet, rotate it 90 degrees, and check to see if the marks jive. If the dont a calibration will cost $60 plus shipping. call 800 879 8000.
Nov 13, 2012 | Hilti Rotating Laser Pri 2 331411
I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
Aug 27, 2011 | Locks & Locksmithing
I bought a 92 grand prix and it has a combination lock on the glove box, how do I find out the combination?
Usually the owner never changed the factory combo (#000). I had no such luck and had to pry the latch and manually open the catch with a piece of thin metal. then I took the lock out and looked for a spaced cog on each tumbler(from the backside). After aligning them in a row, I the rotated all three together up a couple positions to align the combination to it's proper location.
May 16, 2011 | 1992 Pontiac Grand Prix
Como poner la banda de tienpo de un toyota camery
Installation
1.Install No. 2 idler pulley (if removed). Install and tighten bolt to specification. See TORQUE SPECIFICATIONS . Ensure idler pulley is clean and rotates smoothly. 2.Install No. 1 idler pulley and tension spring (if removed). Pry No. 1 idler pulley away from timing belt area as far as possible. Temporarily tighten No. 1 idler pulley bolt. Ensure idler pulley is clean and rotates smoothly. 3.Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See. This will position keyway in crankshaft sprocket at 12 o'clock position.
CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets. Ensure timing belt is installed in original direction of rotation.
4.Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, No. 1 idler pulley, and then No. 2 idler pulley in sequence. 5.Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install No. 1 timing belt cover and new gasket. 6.Align crankshaft pulley key groove with key in crankshaft. Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification. 7.Rotate crankshaft clockwise so cylinder No. 1 is at TDC on compression stroke. Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of No. 1 timing belt cover. 8.Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap. See Fig. 2 . Install timing belt on camshaft sprocket. If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket. Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
CAUTION:DO NOT rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence.
Dec 23, 2010 | 1993 Toyota Camry V6
I am planning to replace the timing belt on my daughter's 95 Corolla and was wondering what I need to align where before removing the belt eg How do I find TDC? Camshaft pulley and Crankshaft pulley...
TDC is top dead center/ remove spark plug on cylinder no. 1/ rotate the crankshaft pulley using a socket wrench and power handle and check if the piston on your cylinder no. 1 reach the top center that is TDC/ remove timing belt cover and locate a synchronized marking on your camshaft and crankshaft pulley/ remove old timing belt/ install a new one but make sure that the mark on your camshaft and crankshaft is perfectly synchronized before putting the cover/ manually rotate the crankshaft pulley again and see if it rotates 360 deg. freely then you can be sure you did the job correctly.
Apr 06, 2010 | 1995 Toyota Corolla
My timing belt broke on my '99 Ford Escort ZX2. Please tell my husband how to replace it. Than k you
Timing Belt
REMOVAL & INSTALLATION
1.8L Engine
Disconnect the negative battery cable.
Remove the timing belt covers.
Rotate the crankshaft and align the timing marks located on the camshaft pulleys and the seal plate.
Remove the crankshaft pulley and hub.
If the timing belt is to be reused, mark an arrow on the belt to indicate its rotational direction to enable correct re-installation.
Loosen the timing belt tensioner lockbolt and remove the timing belt.
To install:
Temporarily secure the timing belt tensioner in the far left position with the spring fully extended, then tighten the lockbolt.
Make sure the timing marks on the timing belt pulley (crankshaft sprocket) and the engine block (oil pump housing) are aligned.
Make sure the timing marks on the camshaft pulleys and the seal plate are aligned.
Install the timing belt.
Loosen the tensioner lockbolt. Using a suitable prying tool, position the timing belt tensioner so the timing belt is taut, then tighten the tensioner lockbolt.
Turn the crankshaft two turns clockwise and align the timing belt pulley mark with the mark on the engine block.
Fig. 1: Timing marks are located on the camshaft pulleys as shown — 1.8L engines
Fig. 2: Make sure that the crankshaft sprocket (timing belt pulley) and oil pump timing marks are aligned — 1.8L engines
Fig. 3: Align the timing belt pulley mark with the tension set mark, at approximately the 10 o'clock position — 1.8L engines
Fig. 4: Check the timing belt deflection at the location shown — 1.8L engines
Mar 28, 2009 | 1999 Ford Escort
Belt tensioner
Take all the slack out of the long side of the belt and I like to use a pry bar to push against the tensioner and it'll take the rest of the slack out. Rotate the engine by hand twice forward and once backwards and double check to make sure your timing marks are still lined up. If so, you're good. If not loosen the belt again, but this time move the cam sprocket 1 tooth advance and do the same thing over again. This should be right on the money after you rotate the engine twice forward and once in backwards.
Mar 16, 2009 | 1991 Honda Accord
Unable to open my DVD player
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
May 27, 2007 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
Cycling Logo
48 people viewed this question
Top Carrier Cycling Experts
John Egan
John Egan
Are you a Carrier Cycling Expert? Answer questions, earn points and help others
