Question about MSI G31M3-L V2 Motherboard
I just installed a msi G31m3 V2 motherboard and now i have no video. I just get a blank screen. Not sure if I have the HDD connected properly or if there's another problem...cn anyone help me with this.
  • joecoolvette
    joecoolvette May 11, 2010
    Let's start with some clarification, so that I can try to solve this problem better. 1.Are you SURE that there is no unused spacer under the motherboard, contacting the bottom of the motherboard? If you are using brass standoff's, and not plastic spacers, AND have a standoff NOT matched up to a mounting hole, it can touch solder joint/s on the bottom of the motherboard. 2.Are you using a SATA harddrive? Has a 7-pin bent elbow Data connector, and a 15-pin Power cable? IF so, DO NOT use a 4-pin whitish Molex power connector, with the 15-pin power cable! 3.What processor are you using? 4.What ram memory? 5.Are you using a graphics card, or plugging the monitor into the motherboard? 6.JPW1 is a square 4-pin power connector on the motherboard. It MUST have power as this is power for the Intel processor you're using. I know it's hard to read this, but these are questions, and not solutions as yet. Supply me some info, and I'll post a solution, or solutions.
  • 28 Answers
If you install the processor and ram correctly and plug in the monitor you should get the BIOS screen. If not something is wrong with the 3 stuffs (mobo,cpu or ram) check also all the power sockets to the motherboard and graphics card.
Posted on Nov 15, 2009
  • 32 Answers
Check your jumper settings on the motherboard and make sure they match specs
you may also try an external video card.
MSI G31M3-LV2, Bios XD settings
Hello the homepage is here:
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html#/?div=Driver&os=Win7%2064
Here is no support for windows 8, and the cpu must support the 64bit
architecture, in order to install the windows operating system.
You must also have, at least 2 gb of ram.
Download the upgrade assistant here:
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8
To find out.
Good luck
Jan 22, 2013 | MSI G31M3-L V2 Motherboard
I installed a new G31M3 L V2 MOBO because my old one (same model) died. Also gone with it was the intel cpu (I guess because of the heat problem). With the new mother board I upgraded my CUP to an Intel...
Make sure that the Power connector are properly connected, also check if the CPU is properly seated to get POST from the Board, since the CPU is new as well as the board you can clear NVRAM on the board take the CMOS Battery out for a couple of seconds then put it back in the CMOS slot then try to turn the unit back on, also check all the rams if properly seated.
Nov 23, 2011 | MSI G31M3-L V2 Motherboard
I want the pin diagram for the power button ect.
Hi, you can download a manual and drivers here:
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html#/?div=Manual
Unzip the file before installation.
The pin layout look like this:
Sep 14, 2011 | MSI 7529-050R Motherboard
Please, I am need manual mother board MSI G31M3-L V2. Obrigado!
http://www.msi.com/service/download/manual-8486.html
then select US
see page 1 of pdf document.
INTRODUCTION
Thank you for choosing the G31M3 V2 Series (MS-7529 v1.x) Micro-ATX mainboard. The
G31M3 V2 Series are based on Intel
® G31 & Intel® ICH7 chipsets for optimal system
efficiency. Designed to fit the advanced Intel
® CoreTM 2 Duo/ CoreTM 2 Quad/ Pentium
Dual-Core E2XXX and Celeron 4XXX/ Wolfdale Series LGA 775 processor, the G31M3 V2
Series deliver a high performance and professional desktop platform solution.
Apr 24, 2011 | MSI G31M3-L V2 Motherboard
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
Brand new G31M3 V2 MSI motherboad, fresh out the box. I hooked up all the wires correctly (i triple checked them) and installed the new graphics card, wireless internet card, and tv tuner card, and...
Remove everything except CPU and 1 stick of RAM. Attach monitor to onboard graphics and under Integrated Peripherals in BIOS there SHOULD be option for display, it needs to be set to PEG so it looks for a PCIe graphics card first. If you still get no picture, DOA motherboard.
Aug 28, 2009 | MSI G31M3-L V2 Motherboard
MSI G31M3-L V2 Motherboard Logo
243 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
