Question about Rockford Fosgate Punch Stage 2 P210D4 Subwoofer - 10" Dual 4 Ohms Punch Stage 2 Series Car Speaker
What sizes of wires do I use to hook up a 10" Punch sub to a pyramid gold series amp,4 channel x 100w,class AB bridgeable?Also how do you hook up a dual 4 ohm sub to a sub box with 1 hookup?
    Problem Solver:
  • 8 Answers
Must be higher than a 12 or your not getting enough amp or watts as you can je
Posted on Nov 17, 2009
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
May 07, 2011 | Sony Xplod 800W Class AB Bridgeable...
Will a sony 600watt amp run a 10 300watt 4 ohm sub?
Yes, but the wattage numbers are pure marketing and have no bearing in reality or fact. In general, given realistic amplifier power specifications, a higher-powered amp will be a better and safer power source for any given speaker than an under-powered amp since the latter will probably have to go into severe distortion to produce the same loudness a high-powered amp can provide cleanly. Distortion kills speakers.
Jan 17, 2010 | Sony Class AB 600W Bridgeable 4-Channel...
Not enough Amp?
You should still get sound even with small amps but it would be rather weak. Check first the source of the signal. Test with different sources to be sure. Check for loose connections.
Oct 02, 2009 | Rockford Fosgate Punch 400W Class AB...
Need to know how to hook up a subwoofer to an amp
thats easy if you have posted the specs of amp and sub.are subs 1 2 4 ohm? what is the power rating of both amp and subs in 1 2 4 ohms.u need to post some info to get help.:]
Aug 27, 2009 | Sony Class AB 600W Bridgeable 4-Channel...
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
Amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have two 15 inch L7 Solo-Baric Subwoofers and need an amp
I would recommend a brand named class D amplifier.
Connect both woofers in parallel (Positive to positive, and negetive to negetive) in a sealed enclosure. Make sure you have no air leaks. By connecting them in parallel the combined impedance will be two ohms. Make sure that the amplifier you choose can handle a load with that low of a resistance. Any high end amp should do this. Buy as much power as you can, but I would say a minimum of 1000W RMS. Beware of cheaper amps advertising "peak power". This can be considered half of what the RMS power would be (1200W peak = 600W RMS approximately).
Next, Run very heavy gauge (zero guage if you can) power line directly from the battery. Protect the wire where it passes through the body with a rubber grommet or otherwise something to keep the metal from cutting into it, and PUT A FUSE IN. I cant stress that enough. Put an 80 amp fuse in line incase you have an accident. Otherwise your car could very well burn!
Want even more punch?
Back at the amp, install the largest stiffener capacitor you can afford 1 Farad or bigger. Install this in a space where it would be protected in the event of an accident (on the inside of the strut tower or somewhere above the axle). There is a whole lot of energy stored in there that you don't want unleashed on you!
If you have any other questions please ask away!
Apr 13, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
165 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
