Question about Skull Candy Skullcrushers Headset
This supersedes my earlier request because there seems to be a problem there. I need to rewire the cable to the headset. I need to wire in the plug and the base boost or if that doesn't work then to take out the base boost and just wire in the plug. If there is a wiring diagram that I can pbtain then I can probably do it all without any further assistance. I couldn't find one on the Skullcandy web site.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa, It would appear that technical documentation for a Skullcandy SCS-SC Skullcrusher Subwoofer Stereo Headphones is not readily available. Still, should you be removing the BASS Boost min-amp, then wiring from the plug to the headphones speakers should be straightforward. Basically, even if the plug has only 3 terminals, the wire would have 4 conductors. 2 of them would be the common or the ground. Perhaps the images below would give you further insights. + + = A continuity tester (DVM / VOM) and a soldering iron would be required. Good luck and thank you for asking FixYa.
Posted on Nov 15, 2009
  • Louie  Role
    Louie Role Nov 15, 2009
    for some reason, the images are missing, am trying again below.
How do I rewire a cut harness car radio of a chrysler town country 2010
If you have original cables match pins. Otherwise there should be a diagram or table (paperwork) explaining where to wire in the new to old wires.
Feb 07, 2015 | Chrysler Cars & Trucks
How do i rewire c15 socket for hot condition 6a line
Black wire to the brass screw
white to the silver
green wire to the ground
Jun 21, 2014 | Earlex LMB150 Steam Master Wallpaper...
Kenwood dnx7100
If someone cut the cords you will either need to know how to rewire them or buy a new headset.
Apr 27, 2014 | DreamGear DG360-773 Headset - Wired...
Plug needs rewired..where do wires solder to?
if its used for aviation then get it done by a prof.
Apr 06, 2014 | Avcomm Ac-200 Pnr Headset
Wire on rt side broken at mid point
Check out my video on how to replace the earbuds.
Feb 19, 2014 | LG HBS-700 Bluetooth Headset
Sound problem
check headset with other audio sources, if same results on all sources then headset has faulty wiring , probably grounded, have it check , if possible rewire.
Dec 27, 2013 | Radio Communications
Can I use an Ipod through this equipment?
U can buy a connector from shop. Otherwise u can modificate a headset plug in cable n a amplifi plug in cable. it's easy i've always do the same with my mp3. Headset cable got 3 wire inside t ground is brown 2other wire can connect 2gether amplif cable got 2 wire, 1 is black or brown it's a ground t other is red. Just connect it 2gether. It's work for me. Keep trying. It's better than spend 20bucks buy a connector. Good luck
Dec 04, 2012 | Audio Players & Recorders
Wiring diagram for turtle beach headset x11
Are you really going to re-wire the headphones? that sounds like such an ordeal. not worth the trouble i found this site that sells the Turtle Beach X11 for like 30 bucks or less. save your self the trouble.
Jun 13, 2012 | Turtle Beach Ear Force X11 Headset For...
1999 police harley davidson rewired bike with new harnmess power
If you have power going to the coil but no spark, you've got something wrong with the "triggering" circuit of you ignition system.
One other thing, if your engine is the TC88 engine, (first year of production for some models) it probably has a "compression sensor" on it. If you have no compression, you will not have any spark. If you have your plugs out of the engine, you have no compression. So, screw a set of plugs into the engine, leave another set in the wires and grounded against the engine to test the spark.
The "triggering system" uses the signal from the ignition timing sensor that is located in the "nose cone" of the engine. Check this wiring from the ignition unit's "Black box" to the sensor. I seem to remember a plug that plugs in for this unit.
I'm afraid that this is about the only help I can give you with a stock ignition unit as I usually work with either earlier igniton systems or aftermarket units. I have very little experience with "stock" Harley units.
Dec 20, 2009 | 2000 Harley Davidson FLHRCI Road King...
Skull Candy Skullcrushers Headset Logo
144 people viewed this question
Top Skull Candy Radio Communications Experts
 Grubhead
Grubhead
woodzowl307
Michael Harrier
Are you a Skull Candy Radio Communication Expert? Answer questions, earn points and help others
