Question about Gateway MX6920 Notebook
Gateway laptop (windows vista) internet won't work
Gateway laptop (windows vista) says that the connection to the internet is there, the switch on the side is on so that the internet is on but the internet explorer wont work, it opens to a blank page and on the tab it says im offline.
    Brigadier General:
  • 10,406 Answers
Within Internet Explorer, click FILE, and WORK ONLINE.
Posted on Nov 14, 2009
Im using a 2Wire Gateway DSL connected via ethernet to a Mac G4, I also have a laptop running windows vista and it has strong wi-fi connection, sending packets at optimal levels and speed. BUT Problem
Vista has a well known flaw of not allowing you to easily change access rights after selecting "public network" in the initial network connection screens. The easiest fix is to change the name of your wifi access point, reconnect, and be absolutely certain to select "home network" when the prompt comes up.
The best solution however is to ditch that crummy excuse for an operating system and upgrade to Windows 7 or 8.
Oct 05, 2014 | Computers & Internet
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
How do I remove windows 8 without uninstalling windows vista??
I'm sorry to say but you are in uncharted territory with Windows 8. It is so new that it is hard to tell what is going on. I would suggested backing up your hard drive and then reinstalling Vista. You will waste more time trying to figure it out then to reinstall the OS.
Sep 02, 2012 | Gateway Computers & Internet
Laptop running windows vista won't connect to router in Europe.
You need to call the internet provider. They more than likely have a different protocol to set up in order for your internet to work.
Jun 25, 2012 | HP Computers & Internet
New download of windows 7 won't retain or create internet connectins
Ok, this is conflicting... won't retain or create!! Doesn't it have to be created to retain it?
Did it connect before you downloaded windows 7? Exactly what happens when you try to get on the internet? Do you have the wireless switch on the laptop turned on? Do you see your wireless router? If so did you put the password in correctly? If not, it will never connect.
Jun 03, 2012 | Compaq Presario CQ62231NR Notebook
Dell inspiron 1525 not connecting to internet
I am one of the Dell Certified System Expert.
For internet connection, there are two ways to connect to the internet. One is through wired connection (connecting LAN cable) and connecting to wireless connection (through wireless router or through wireless Modem WLAN).
For wireless check the switch located on the left side of the portable after switching check the status light located at the front left of the computer.
check the driver if it is properly installed meaning no bang(!) or question mark(?) for both ethernet (LAN port) and Wireless Device.
To check the driver go to control panel then device manager. Check the network and you should be seeing the ethernet and wireless device. If not installed use the driver cd that came with the computer.
How to check the internet connection.
For Wired connection:
First check the cable, check the LAN port in the computer there should be blinking lights, if none try to reseat the cable. Check the ipaddress of the computer and the default gateway.
This is the instruction to get the IP address and default gateway.
For windows xp
1. Click start, then choose run then on the box type CMD then click ok.
2. on the black screen type ipconfig. get the ip address and default gateway.
3. normally it will give you 192.168.XXX.XXX
4. try to type ping 192.168.XXX.XXX (this should be the gateway)
5. If you receive replies, then you are connected to the router/modem
6. then try to ping www.yahoo.com
7. if still reply then you are connected to the internet already, might be your issue is browser or security on the computer.
For vista and Windows 7
click windows then in the start search type cmd, you should be seeing cmd on the top, right click then choose run as administrator. then follow steps 2-7 above.
For wireless connection
Check the switch, and the status light, if all are checked checked the ip address and default gateway as well, the instruction is the same above.
For more information about setting up your system please refer to the link.
http://support.dell.com/support/edocs/systems/ins1525/en/SG/Y465HA01MR.pdf
Hope this will help you a lot.
Thank you for choosing fixya
Mar 01, 2011 | Dell Inspiron 1525 Notebook
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
I have an active internet connection. in fact, my pc works with this connection.. i tried to connect my laptop to the internet, but it didn't prompt as it usually do..it used to show the sharing icon on...
hard to answer your question without knowing what Operating System you have on your PC and laptops connections, eg. LAN, wireless etc.
If you have windows XP you will need to check Network Connections on your laptop to make sure the Internet connection is showing as connected.
Click on Start - Control Panel -- network connections.
Check if Internet gateway is setup
If not go to Internet Options in Control Panel and setup the Internet connection using the right buttons.
I cannot guide you if you have Vista or Win 7.
May 07, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
I cannot get my laptop to connect to the internet either wirelessly or hard-wired. I have two other laptops, connected wirelessly, and a desktop connected via hardwire. It recognizes the router but says...
if you are trying through wireless, first unplug the wire from the laptop,
make sure that the wireless switch on your laptop is turned on.
click on start, control panel, network connections/network & internet/ Network and sharing center..
right click on wireless network connection Icon, if it says disable, it means it is enabled already.
then click on status..
from here the steps would differ from OS to OS
then click on Support tab (for XP)
check the address type, it should be "Assigned by DHCP"
and if you see the IP Address starts with 169., it is a bad IP and needs to disable the connection and enable it.
if the connection type is "Assigned Manually, right click on wireless network connection icon and click on properties and click Internet Protocol(TCP/IP) and click on properties, in this window, check the option "Obtain IP Address Automatically from DHCP"
click ok and OK ..
again right click on the wireless network connection icon and click on view available networks... click on your router name and click on connect..
now check the functionality.
if you are using windows 7 or vista,
click on status, click on details for the IP Address..
We see DHCP Enabled as YES or NO instead of "Adress type"in XP
if it says no, it means it is assigned manually. to change to DHCP , right click on Wireless Icon, select properties, click on IPV4 IP address and click properties, then select obtain automatic..
then try again..
hope this works,
Narendra Tirunahari
Feb 18, 2010 | Gateway 7330GZ Notebook
I cant find video controller driver for gateway cx2610 for windows 7
Gateway doesn't seem to have a driver created for windows 7 The only alternative I could suggest is to try and download one from ATI's website, a Vista or windows 7 driver should work
Nov 02, 2009 | Gateway CX2610 Notebook
Gateway MX6920 Notebook Logo
213 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
