Question about SanDisk Sansa E280 MP3 Player
Sansa e280 not formatting
I try to repeatedly delete a corrupted album from my player, but the second I do, it instantly says that the player can no longer be read. Upon inspecting the CD folder more closely, it appears to loop into itself forever.
Formatting also doesn't work, as the player instantly displays an error message and becomes unresponsive.
Is there anything I can do shy of buying a new player?
  • 1 more comment
  • gl48083 Jan 10, 2008
    some music can play, but some can't
  • FloJama Feb 07, 2008
    I hav ethe exact same problem.
    I tried deleting everything off the mp3 music file.
    But it jus keeps appearing.?!!?
    :s Im soooooo lost.
  • Anonymous Jun 13, 2008
    same problem!
Disconnect player from computer - switch to MSC mode, under settings and then USB modes. Plug player into computer again and format the Sandisk player using Windows (my computers, right-click menu). Formatting may take up to 10 - 20min depending on size of memory. Disconnect from computer; let the player reboot; should go back to the main menu. Reconnect to upload new music!!! :)
Posted on Oct 12, 2008
Lets the battery runs out and then try to charge it again, it worked for me
Posted on Jan 21, 2008
I cannot delete songs from my Sansa e280. I have tried using both USB settings - MSC and MTP. When I try using "My Computer" it says it is deleting the files but they are still on the...
They are probably corrupt files. You will never be able to delete these unless you format your device, which unfortunately will delete all of your songs.
To format: Connect it to you computer, go to my computer, right click on Sansa and click on format. Once the format process has started don't interupt it. You will have to re-load all of your songs back on to the player, but at least your corrupt files will be deleted.
Mar 13, 2011 | SanDisk Sansa E280 MP3 Player
How do you reform a Sansa E280E MP3 player. video files stored is corrupted and unable to be deleted through normal means.
Hello there...
To format your mp3 player please do the following
Connect one end of the USB cable to your player and the other end to an open USB port on your computer. Your computer will recognize the new device.
Double-click "My Computer" on the desktop. You will see your Sansa e280 player's icon listed as a removal disk together with other hard drives on your computer.
Right-click the Sansa e270 icon. Scroll down and click "Format." When the format window opens, click "Start." The formatting will erase any current information on the drive. Depending on the memory capacity, it could be a quick process or take a little longer.
I hope this solves your problem,,,
Jul 03, 2010 | SanDisk Sansa E280 MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
I need to recover deleted memory
Try re-installing the drivers or updating it online :)
Apr 27, 2009 | SanDisk Sansa E280 MP3 Player
Cannot delete "bad track"
try formatting your mp3 player and then syncronizing songs back on to the mp3 player.
Sep 13, 2008 | SanDisk Sansa E280 MP3 Player
Corrupted files
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
May 05, 2008 | SanDisk Sansa E280 MP3 Player
Is there an easy way to delete all the music off of my mp3 player?
or
-Tha Mp3 Doctor
Apr 17, 2008 | SanDisk Sansa E280 MP3 Player
Can't Delete
try formating the disk,
just right click on the drive in windows and format.
that should clean it up.
as it is corrupt.
Mar 15, 2008 | SanDisk Sansa e250 MP3 Player
Won't be deleted
Go ahead and do this, in case the DB is corrupted:
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
When i connect to the computer, i can add songs, but the songs on it dont show up
I don't know if you've inadvertently deleted the music folder, but that's what I did, when I deleted all the folders by mistake, thank heavens for in-store warrenty, they replaced it with another one. What I noticed on my replacement is synchronizing with media player doesn't work, it creates ghost folders and thinks music is there when it isn't, I don't understand it. Solution: open two windows for my music and sansa e280 music, then just drag and drop the folders; what I noticed is that in my music the folders are named by artist, and I prefer to see them by album, but when I view them in the player, I see the albums with the tracks in the right order.
Aug 17, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
119 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
