Question about Woodcraft Pirate Ship 3d Construction Kit
Not sure where to begin with the Seattle Space Needle Kit
Tell me how I can get a space between words when embroidering a sentence
There is usually a "space" character in the alphabet--probably looks like an underscore as that is how it will stitch (the thread will not have a break in it unless you stop the machine, tie off the thread, move the needle over a bit and begin the next word).
Jan 06, 2017 | Computers & Internet
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Venezia vae know boil water for coffee coming out the head
It sounds like you need the tune up kit. I got mine at Seattle Coffee Gear. http://www.seattlecoffeegear.com/seattle-coffee-gear-tune-up-kit-for-saeco-via-venezia. It was really easy to unscrew and replace the parts. Good luck
May 12, 2014 | Saeco VIA Venezia
Hi i have a 1975 honda cb200..new plugs,points and timing set..new carb kits inc needles.tried different coil and condenser....great untill engine up to temp..then flat spot off tickover......also black...
Move the clip on the jet needle lower on the needle. This will help with the flat spot by giving fuel earlier. The black smoke is a rich fuel mixture. Check to see that the carb kit had stock jet sizes. Be sure to synchronize the carb slides so they both begin to lift at the same exact moment. tombones49_223.gif
Aug 08, 2011 | 1974 Honda CB 200
I have found the plans for the Seattle Space needle woodcraft construction kit 3d puzzledo not give any detail as to what pieces fit to in relation to other pieces just what reference to the front picture...
I bought space needle model #814901 and was able to put most of it together using the pattern on the back and the pic on the front. I was able to match the numbers/letters for the most part. I have ended up with an extra circle, and some numbers that have no corresponding #s. Still, the end-product does look pretty much like the one on the front. I bought this model in the gift shop at the space needle. I saw a completed one downhill in an expresso shop on the waterfront across from the sculpture garden. I go to Seattle a couple of times a year and plan to check out the expresso shop again.
Aug 15, 2010 | Toys
Woodcraft Pirate Ship 3d  Construction Kit Logo
57 people viewed this question
Top Woodcraft Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Woodcraft Toy Expert? Answer questions, earn points and help others
