Question about Acer Aspire One PC Notebook
I keep getting found new hardware on base system device but when i go to install it says it cant find the hardware but it keeps coming up with found new hardware every 2-3 min
  • blueduckky Nov 14, 2009
    hello thanks for the fast reply i went to device manager there is no unknown device tab it has other devices with 3 base system device tabs with a yellow ! next to them
  • 434 Answers
Something installed on your computer doesn't have the drivers installed so it can run. Click on Start, Control Panel, Device Manager,(look in the upper left corner for this). You should have a list of all hardware installed for your computer. In this list should be an, "Unknown Device". Double click on the device, Click on the Driver Tab at the top of the new screen, then click on disable.
This will not install the drivers, but will keep the annoying popup away for good. If you find out which device isn't installed, you can go back to this page and click on update driver. Or just leave it alone. If you don't have anything noticeably not working, like sound, it probably isn't necessary. Hope this fixes the problem...
Posted on Nov 14, 2009
Base system device and TI Ultra Media Firmware Loader Device.
Maybe the data on the installation disc is corrupt. I'd uninstall it, try to dl a new updated version on line and install it. That might work for you.
May 21, 2017 | HP Compaq nx9105 Notebook
I get this error message.. an error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again. Nothing seems to work,, this message...
#Click Start , select Settings , and then click Control Panel .
#Double-click System . The System Properties dialog box displays.
#Click the Hardware tab.
#Click Device Manager . The Device Manager dialog box displays.
#Click the plus sign (+ ) next to Universal Serial Bus Controllers .
#Click the USB Composite Device entry, and then click Remove .
#Disconnect the USB cable from the All-in-One, wait for few seconds, and then reconnect the cable. The New Hardware found dialog box displays.
#Click Next through all of the screens that display while the Wizard installs the USB composite device, and then click Finish .
Regards
Riztech
Oct 24, 2010 | HP Officejet 7310 All-In-One Printer
Hello, Whenever I boot up my machine I get an error message saying new hardware found - base system device. It then doesn't find any software to instal and goes away after a few clicks. However, I have...
Hello Dear,
I would suggest to use the Chipset Drivers CD to install all the drivers. I hope you would be having the CD which comes with the Laptop.
WIth regards
FIXYA team
Oct 09, 2010 | Dell Inspiron 6400 Notebook
Hello , i have a problem with my Dell Dimension 4700, the problem is that i recently uninstalled the SoundMAX driver and i don't know how to get it back could you please help. thanks
Follow the solution for your Operatig System;
Windows XP
1.
Right-click My Computer>Properties>Hardware> Device Manager>you will see a yellow icon>right-click icon >
select
a.Update Driver>note,this will take to the New Found Hardware Wizard>proceed as in 2 below
b.Properties>Reinstall Driver>note, also takes u to 2 below> proceed as in 2 below> Restart system. U should be good to go
2.
Found New Hardware Wizard>select No, not this time> click Next> 1st Option is checked i.e. Install the software automatically (Recommended)> click Next>wait for program to reinstall drivers, also cancel any warning that comes up & it will come up with a Windows File Protection Console i.e. You chose not to ...Are you sure you want to keep these unrecognized file versions? click Yes> Completing the Found New hardware Wizard comes up> click Finish.
3.Restart System.
4.U're good to go
Vista
Right-click Computer>click Properties>click Device Manager>User Account Control console comes up> click continue>you will see a yellow icon>right-click icon >
select Action tab> Click Scan for hardware changes> you will see a yellow icon on your audio device> wait a while> You should be good to go
a.Update Driver Software>same as 1a. above
b.Properties>same as 1b. above
Feedback needed and don't forget to give thumbs up! ciao
Aug 25, 2010 | Dell Computers & Internet
My computer keeps asking to find software to install mtp device for my lg fm37 and i cant find it, so my computer won't connect to it. what should i do
no problem, you will be presented with this option in your atempt to install the device
Welcome to the Found New Hardware Wizard. This wizard helps you install software for:
MTP device
If your hardware came with an installation CD insert it now
What do you want the wizard to do?
Install from a list or a specific location (select this the advanced option)
Click next to continue
here look for install from a list or specific location
please select the chose USB Hub .
their you go.
thanks for using FixYa.
Mar 23, 2010 | Audio Players & Recorders
Computer cant open sansa clip
Make sure the lock switch isn't engaged.
Double-click My Computer, and see if there is a Sansa icon (some computers will only show it as a removable drive or an MTP device).
If the computer is not recognizing the player:
disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa Clip MP3 Player
Could not detect ethernet card or device
hi there what you can do is 1 of 2 things first you can shut down the computer and remove the card and then turn on the pc and let it fully boot then normally turn off the pc then reinsert the card and see if the new hardware found comes up on restart and installs the drivers for you. or you can go to device manager and do a right click on your network adapter and select scan for hardware change and see if it can find it that way ok i hope this helps please try to keep me posted
regards mike
Feb 14, 2009 | EliteGroup RS480-M (RS480MV10) Motherboard
Device not found code41
you should install the software first. then the hardware, make sure you have the cables on right and in all the way, somethimes the cord comes lose
Dec 23, 2007 | Microsoft Windows XP Professional With...
Cannot install the device
With regards to this issue, I would suggest you to download windows update since samsung MTP devices are generic driver loaded by microsoft. Then after you have downloaded the windows update press and hold the play button of your device while you are connecting it to your computer, if this is successful a Found new hardware message will pop up on your screen then just follow the on screen instruction on how to install your device. Hope this helps. PEACE!
Aug 27, 2007 | Samsung YP-U2JQB MP3 Player
Acer Aspire One  PC Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
