Question about GE Dryers
How do I put a belt on an electric dryer - GE Dryers
  • GE Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 15, 2009
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Cannot tighten the drive belt on my Fisher and Paykel DE04 electric dryer.
Remove the belt from the motor and pull it out of the tensioner. Put it back through the tensiner from the other side of the bracket. (If you put it in right to left, this time, put it in left to right ). The belt will seem very tight to try to get onto the motor but, it's supposed to.
Feb 20, 2009 | Fisher and Paykel DEGX1 Electric Dryer
How do i put belt on hotpoint electric dryer
If you have the belt already, then you can put it on much the same way you put a chain on a bicycle. Put it on the drum first, then ease it on the pulley and turn the drum slightly to make it slip all the way on.
Jan 27, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Dryers Logo
47 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
