Question about Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive
Replacement hdd for a Toshiba MK4026GAX (ATA)
I have a Dell Latitude D610 which has worked reliably. However I suspect the hdd may be failing (disk utility Palimpsest) and I'd like a compatible, reliable replacement for the Toshiba MK4026GAX ATA 40GB HDD. Any recommendations?
    Brigadier General:
  • 10,406 Answers
Any brand-new ATA hard-drive (you probably won't find any new hard-drive smaller than 80GB) will be compatible. Pay a few extra dollars for a 7200 RPM drive (rather than 4200 or 5400 RPM).
Posted on Nov 14, 2009
Testimonial: "I was thinking along those lines as I am considering a Seagate (Barracuda?) ST910021A drive. Many thanks."
Fatal system error on my dell latitude D610 intel centrino
This sounds like a hard drive issue or windows has been corrupted, if you have a recovery disc try and reload your operational system, if that fails have the hardware tested for possible replacement.
Sep 17, 2012 | Dell Latitude D610 Intel Centrino 1.86ghz...
My laptop has failed to start up. It gives me an error code 1000-0416. It's a Dell latitude D610. What steps should i take to fix this? Thank you.
hello, Plug your laptop to an external monitor and restart,maybe it is a VGA problem,if it does not start change the RAM,if it does not start again,then there is a problem with the motherboard
Nov 18, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
Can the MK4026GAX @5400 rrm be used to replace my deceased Toshiba MK3021GAS @4200 which fits into my dell inspiron 8500 using a adaptor directly into the recepticle (slide in from side & screw on...
Yes, all IDE 2.5-inch disk-drives use the same pin-out. SATA-interface disk-drives have quite-different interfaces than IDE drives, but all SATA devices share a common interface.
Nov 06, 2010 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
What laptops are compatible with toshiba mk4026gax hard drive?" I am trying to find a used laptop on ebay that will work with the mk4026gax hard drive I have been using in my Dell Latitude D600 which is...
Hi, probably any laptop made before 2002, will take this hard drive. to get any joy out of a second hand laptop, check you can upgrade the memory to a minimum of 1Gig, also try for a P4 processor; this will reward you in the long term, for speed and reliability.
Sep 08, 2010 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Dell screen comes on and trys to load up
Hi
Seems like the hard drive has failed, or there is no hard drive in the laptop, replace it with a new one.
This part of the service manual shows you how to replace it:
http://support.dell.com/support/edocs/systems/latd610/en/sm_en/hdd.htm#wp1123687
Dec 21, 2009 | Dell Latitude D610 Laptop Computer -...
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Latitude D610 dvd player won't work
Try a CD ROM lens cleaner. If it fails then I suggest you buy a new one. It is easy to change it: there is a release switch at the bottom with a screw. Open it and remove the old one. Slide the new one into its place.
Aug 05, 2009 | Dell Latitude D610 Laptop Computer -...
Toshiba MK4026GAX (hdd2193) 40 GB Hard Drive Logo
1,384 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
