Question about Jack Lalanne Power Juicer 250 Watts
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Posted on Oct 14, 2012
  • 3 Answers
I have the same problem! Now I can't screw the grater onto it and therefore I can't use the juicer. On the Jack Lalanne Website I found no replacement part.... I think you will have to buy the complete part (motor) which cost $50!!!!! not happy about that... Dennis
Posted on Nov 29, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
How do I remove top plastic round part from the rotor of the motor?
The manufacturer warrants that your Jack LaLanne Power Juicer is free of defects in materials and workmanship and will, at its option, repair or replace any defective juicer that is returned. The Jack LaLanne Power Juicer's motor is warranted for the lifetime of the original purchaser, and all other parts and components are warranted for 60 days from the original date of purchase. This warranty is valid only in accordance with the conditions set forth below:
1. Normal wear and tear are not covered by this warranty. This warranty applies to consumer use only, and is void when the product is used in a commercial or institutional setting.
2. The warranty extends only to the original consumer purchaser and is not transferable. In addition, proof of purchase must be demonstrated. This warranty is void if the product has been subject to accident, misuse, abuse, improper maintenance or repair, or unauthorized modification.
3. This limited warranty is the only written or express warranty given by the manufacturer. Any implied warranty of merchantability or fitness for a particular purpose on this product is limited in duration to the duration of this warranty. Some states do not allow limitations on how long an implied warranty lasts, so the above limitation may not apply to you.
4. Repair or replacement of the product (or, if repair or replacement is not feasible, a refund of the purchase price) is the exclusive remedy of the consumer under this warranty. The manufacturer shall not be liable for any incidental or consequential damages for breach of this warranty or any implied warranty on this product. Some states do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you.
5. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
If you want to order or have questions about specific parts or accessories, feel free to call us at our customer care department:
Phone: 1 (973) 287-5150
Procedure for Warranty Repairs or Replacement
If warranty service is necessary, the original purchaser must pack the product securely and send it postage paid with a description of the defect, proof of purchase, and a check or money order for $29.99 to cover return postage and handling to the following address:
Tristar Products, 500 Returns Road, Wallingford, CT 06495.
Sep 27, 2014 | Jack Lalanne Power Juicer 250 Watts
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
How do I remove the grater/filter from juice collector to clean it? Also the juice collector from the drive shaft? Thanks
You have to lift off the juice collector (the black part around the grater)-you have to use a little force-then you'll be able to take out the grater.
Jan 10, 2011 | Maximatic EJX9700 Juicer
How to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Mar 15, 2010 | Salton Juicers
Broken plastic screw from motor shaft
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Breville je2 (anthony worrell juicer) lost the blade!! slicer!!! thing
Am currently looking for a spare part for mine. If I fail to find it, u can have my grater bit!!
May 02, 2008 | Breville JE3 Juicer
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
Jack Lalanne Power Juicer 250 Watts Logo
443 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
