Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Cant find driver when i plug in? 320 gb simpletech portable hard drive-----------DOB No :96300-41001012
sriramoju
  • 171 Answers
SOURCE: lost software
For which operating system you require if you want for win98 you can download from drivergide.com
Posted on Feb 24, 2008
SOURCE: Simpletech 320 GB
how do you open it?
Posted on Mar 05, 2008
  • 11 Answers
SOURCE: Drivers for simple 160gb
To access an external USB drive in Windows 98, you need to be using Windows 98 SE (Second Edition). Before SE, there was no USB support in Windows 98.
Even then, you will probably not be able to access the full 160Gb of the hard drive. Your best bet is to upgrade to a newer version of Windows, such as 2000, or XP. I know that, depending on your hardware, that might be asking a little too much, but to support all these more modern gadgets, you're going to have to give up on 98 eventually.
Hope this helps.
Posted on May 19, 2008
SOURCE: SimpleTech 320 gb. Code 10 Problem
no me abre simpletech mi correo rufoteama@hotmail.com
Posted on Oct 17, 2008
safenude
  • 124 Answers
SOURCE: SimpleTech 320 GB hard drive not recognized by PC
Windows likes to play with drive letter assignments, especially when you remove a device without using the "safely remove hardware" icon. When you plug it back in, Windows may think that you've plugged in a new one and assign it a new drive letter. Try this:
Your computer can use up to 26 drive letters, from A through Z. Use drive letters C through Z for hard disk drives. Drive letters A and B are reserved for floppy disk drives. However, if your computer does not have a floppy disk drive, you can assign these letters to removable drives.
Before you modify drive-letter assignments, note the following items:
  • Changing the drive letter of the system volume or the boot volume is not a built-in feature of the Disk Management snap-in.
  • Many MS-DOS-based and Microsoft Windows-based programs refer to specific drive letters for environmental or other variables. If you modify the drive letter, these programs may not function correctly.
uparrow.gifBack to the top How to assign a drive letter loadTOCNode(2, 'summary'); To assign a drive letter to a drive, a partition, or a volume, follow these steps:
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
The drive letter is assigned to the drive, to the partition, or to the volume that you specified, and then that drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool.
I hope this does it for you. Thanks for using Fixya!
Posted on Jan 26, 2009
I have a SimpleTech 320 GB external hard drive. It suddenly stopped appearing in My Computer. When I turn it on, it makes a repetitive sound that seems like a warning of some kind...what is it? It sounds...
Hello and welcome to the TSF. If the external drive has provisions for external power you'll need to plug that in, usb ports cannot power a 320 drive. If the drive has 2 usb plugs (one for additional power) you'll need them both plugged in, and I would suggest that the laptop should also be running off of external power rather than battery. If you disconnect the usb drive or any other usb device without first stopping the device then sometimes the usb ports will fail to recognize the device when it is plugged back in, a simple reboot should do the trick. You can also check in the device manager for any yellow exclamation marks on your usb host conrtoller and see if the driver for it is in need of an update.
Any drivers you need should be on simpletech's website, though normally you should not need any for a usb hdd. If the power cord/a/c adaptor is faulty or the hdd is loose in the enclosure(thus not making good contact) then you should pester simpletech to either replace the cord, a/c adaptor,or unit, and see if there are instructions on how to take apart the enclosure and reseat the drive/connections.
__________________
Nov 07, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
Transfering data
If you are having issues accessing the drive i've encountered that situation before
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Mar 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
168 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
