Question about Ryobi 18-inch Electric Chainsaw Chain Saws
Has Ryobi RCS 3535A chainsaw a fuel bulb priming
Has a Ryobi CS 3535A chainsaw a fuel bulb priming system?
    President:
  • 2,220 Answers
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Posted on Nov 15, 2009
Why won't my chainsaw prime?
if no gas will enter priming bulb at all I see only a few possible things for this
(1) gas line broken/melted
(2) filter looks good but has internal plug
(3) primer bulb has a small crack in it (most common )
Apr 30, 2015 | Ryobi RCS3535CA Petrol Chainsaw 35cc...
Echo Cs-400 chainsaw. Standing the carb up with the sliver vent on top which fuel line goes to the 90° inlet on the bottom and which line from the primer bulb to the carb?
The lengths of the line and,or the bends in the line . I would say the line from the bulb would go the carb since it is used to prime or,choke the carb.
Apr 05, 2015 | Echo Garden
No fuel (2 stroke) getting into priming bulb of Ryobi petrol chainsaw 18"
Change the fuel filter in the tank, if this does not help there is dirt in the carb, remove the carb, under the pump diaphram is a filter screen, replce this.
Apr 07, 2011 | Ryobi Garden
14" Ryobi petrol chainsaw will only run for 10 seconds
You are on the right track. Keep priming which indicates the fuel mixture is too lean to run. In other words the fuel line is partially clogged up. A drop of water on the gas tank would cause this problem. The fuel is fed on the suction basis. So clean up the fuel tank, (disassembly the carburator) reservoir, needle, float, offrice and fuel filter. A can of carburator cleaner (spray one) is a big help.
Jun 04, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
943 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
