Question about Juicers
Fridge keeps coming on - the freezer is frozen at the back outside it feels hot.
  • 77 Answers
Unpug the fridge let it sit open and thaw out pull off the back wall in the freezer check your heater and bi-metal.
Posted on Nov 15, 2009
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
May 20, 2014 | Salton JM411 Juiceman II Elite Juicer
I am trying to disassemble. I have done it many times, but the basket won't come off the base this time. I have poured hot soapy water through in forward and reverse. Not working
Many times when juicing very fibourous produce the bowl(basket) can get stuck and you can loosen it by gently tapping on the pulp spout or juice spout to the counter clockwise motion(right), this will loosen the bowl.
Aug 07, 2011 | Omega Juicers VRT330
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
The cutter is stuck how can I get the cutter off of the champion juicer?
I have had this happen in the past...couple things you might try.... put it outside or in the freezer to cool it down. next i have dumped olive oil 'around' the end of it that is butted against the unit- some should seeps down and then i used a dull butter knife or steak knife to wedge in there to pry it off.(genlty) in different positions. If it is rusted on, well that's another matter entirely. But if it's just stuck, could be that you haven't oiled it each time? or my other guess is they aren't making the cutters like they did 25 years ago as i have had 3 champtions and more problems with the new ones and cutters jamming (i put a coule drops of olive oil into the hole in the cutter each time). and as a last resort a big burly man with gloves and feet to hang on to it and jimmy it off LOL good luck ;-)
Jan 08, 2011 | Champion G5NG853S Household Juice...
Cleaning after juicing
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
My juicerator will not run with the stainless steel juice bowl attached. It seems to rub to a halt.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 11, 2010 | Acme 6001 Juice Extractor
Jack Lalanne pusher is stuck in the shoot, was put is the wrong way. Can not pull it back out. Any suggestions.
Heat or cold makes things small or big. Soak it in warm water or put it in fridge then try to take it apart. Hope it helps.
Nov 19, 2009 | Jack Lalanne Power Juicer (Stainless...
Sir,there is a small hole in my freezer part
Must be repaired by a "Certified" technician.
Apr 30, 2009 | Juicers
Tighten bolt is frozen
WD-40 and let it sit for a few hours and it came loose. Had to wash it good before using it.
Jun 11, 2008 | Back to Basics NS1000 Nutri Source Juicer
The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Oct 06, 2007 | Acme 6001 Juice Extractor
Juicers Logo
24 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
