Question about Plumbing
How do I take my faucet off? It's a Grohe Lady Lux. We are trying to replace.
  • 119 Answers
You need to remove the sprayhead and hose from faucet and underneath you will see a brass threaded tailpiece that the mounting nut is connected to you need to turn the threaded piece counter clockwise.The faucet came with a paddle handle tool that fits in the brass tailepiece but I have used a basin wrench carefully to loosen without damaging threads
Posted on Nov 15, 2009
Grohe concetto faucet, 34270, leaking at lever handle when moving lever up and down.
It's a complete cartridge that you need to replace. Contact Grohe and they should send you out a new cart. under their limited lifetime warranty
Feb 16, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Hello: My Grohe Lady Lux Cafe kitchen faucet has become loose where is it attached to the sink. How do I tighten it back up? David
You'll have to go under the sink and look up were the faucet comes through. You'll see it's held in place by a large nut. This nut needs to be tightened. Unfortunately working in the tight space under the sink is a pain in the ****, just be patient and you should be able to tighten it. TIP: Have someone hold the faucet on top in the position you want it.
Feb 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have a water pressure problem with a Grohe Lady Lux Cafe faucet
I solved the problem by unscrewing the part of the handle which attaches to the "pullout" braided cord. There was another strainer in there which has some debris which was blocking the water flow.
John Was.
Nov 16, 2008 | Plumbing
How to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Oct 11, 2008 | Plumbing
Plumbing Logo
120 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
