Question about Insignia PD10135 Portable DVD Player
Connecting a portable dvd player with only an av port to a tv
  • 975 Answers
There is a special AV cord that connects to a TV ,
MINI PLUG TO 2 RCA , one is ( yellow) VIDEO & the other is AUDIO , get it at RADIO SHACK or WALMART , hope it helps , AJ
Posted on Nov 14, 2009
Bush 8382i portable dvd player wont fit the av leads to connect to the TV
AV lead sockets pins are of standard types. It has an international standard. See it.
Jun 05, 2012 | Televison & Video
I need the cable to connect both dvd and the screen together?
well if your tv has only has one av connection port set then you have to plug one in when you want to use one
If it has two then you can plug both of them in at once
Aug 21, 2011 | Durabrand Portable DVD
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
Trying to watch DVD played on portable Insignia player on the TV
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Apr 07, 2009 | Televison & Video
Disconnected system to install new carpet now i'm stuck
Try these...
1. Identify the Video out,Audio Out ports of the player. Normally they will be marked as AV Out for video,L(Left Audio) and R Out.
2.Identify the Video In,Audio In ports of the TV
3. Connect AV Out from the DVD to the AV in of TV,Audio Out of the DVD to the Audio in ports of the TV.
4.If the TV is Mono (means, with a single Audio in), connect to any one of the Audio port of DVD.
Mar 13, 2009 | Televison & Video
I have purchased a new DVD Player. Please help me connect to a TV with cable.
You need a Scart cable to connect the two. The instruction manual should tell you which port to connect to on the DVD (usually TV). The port on the TV should say AV in or similar . Sometimes you have to tune a TV channel to view the DVD but usually if you select AV on the TV it will play automatically.
Oct 08, 2008 | Televison & Video
GPX PD808B Portable DVD Player
The pin on a regular 3.5mm av to rca is TOO SHORT. If you get the unit from GPX, you'll note it is a bit longer. I found this problem also affected Sony and other portable DVD players - the regular 3.5mm plug is TOO SHORT. I haven't found a source other than GPX for the av cable with the correct length plug. Weird but true.
Sep 02, 2008 | GPX PD808B Portable DVD Player with Screen
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Insignia PD10135 Portable DVD Player Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
