Question about Philips J44414
Philips pc camera sic4750/27 doesn't work says I need a driver running on window 7 have tried the original cd.
    Brigadier General:
  • 10,406 Answers
See the manufacturer's web-site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=US2-J44414&slg=en&scy=US
and then click "call customer support", since no drivers for this 2007-vintage web-camera seem to be available for Windows 2009.
Posted on Nov 14, 2009
I need a free driver for my webcam philips sic4750/27 for windows 7
Hi Jorge
Try this Url I posted for getting your driver. You said that you are using windows 7 but sometimes the same driver for an older operating system will work. Try the driver found here for windows XP. Download the zip file, extract it , then click on the setup file.
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=SIC4750/27&hlt=Link_Software&mid=Link_Software&scy=CA&slg=AEN
Nov 28, 2014 | Philips Pc Camera Sic4750/27 In Box With...
I have emachines el1360-ur30p running windows 7 and doesn't recognize cd/dvd
Was it working fine before? If it does, then you would need to update the driver for your DVD.. Or you might have an outdated DVD driver. You can use RadarSync to update it.
David
Feb 24, 2013 | E-Machines eMachines Desktop PC
No connection between my z7u and my windows 7 computer!, how can i download the driver?
when you bought the camera,is the seller give you the driver CD?
normally,windows 7 doesn't need any driver to connect a device, there's might be an error when the windows installed the driver
I recomend you to go to the Device Manager,uninstall the current driver,and try to connect your camera again,the windows will re-install the driver automatically
And if you can't find the driver on the internet,you can go to the shop and ask for the driver CD
If those doesn't fix your problem,give me the detail series of your camera and i'll search the internet for it :-)
Aug 22, 2012 | Sony HVR-Z7U DV Camcorder
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
Hi I have philips pc camera sic4750 I bought, I could not download throught the cd that came with it thanks
Philips PC Camera SIC4750 is only compatible with OS Windows 98 Second Edition, Windows 2000 & Win XP. (Only 32Bit system ie x86)
FAQ from Philips (Ref. Link)
Question: Can I use my webcam with Windows 7 or Vista ?
Answer:- At the time this webcam was designed, Windows Vista and Windows 7 operating systems did not exist yet. Unfortunately, the internal hardware of the webcam does not match the requirements of these operating systems. Therefore we cannot provide a software upgrade (driver upgrade) to support Windows Vista or Windows 7. We apologize that we are not able to support you in this matter.
Too bad Philip do not provide the drivers if your are Using Vista or Win 7 or any x64Bit system.
Dec 07, 2010 | Computers & Internet
Replacement CD software
Diana..,
I located the usb driver you need to make the connection with the computer . on this location you will find the driver for windows Xp ...cause I do not located for vista .. if you use other operating system let me know and I will see what I can do ...( I do located for Mac too all but vista )
http://www.mediafire.com/file/qzz2gljmgiz/fuji finepix driver xp.exe
have a great day ..and Enjoy!
Aug 04, 2009 | Fuji FinePix 2800 Zoom Digital Camera
I need help to instal a webcam spc110nc
I need the driver for this webcam spc110nc to work with skype.
Aug 16, 2008 | Philips ToUcam Fun Webcam
Philips J44414 Logo
195 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
