Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
I have a gas cook stove. I would like to know how i can clean the burner grates. Please tell me something.
    Problem Solver:
  • 5 Answers
Place them in the oven on self clean or if you do not have the setting, place all the parts into a black trash bag, spray oven cleaner on the surfaces and place the trash bag in the sun for a few hours. Rinse and spot clean the balance. This also works for re-seasoning cast iron pans
(the bag thing). You may need a few applications for the pans....
Posted on Nov 15, 2009
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
My Jenn-Air range top will spark but no ignition. Gas does not seem to have enough pressure on that burner
Generally the issue with this is not that you don't have the correct pressure but the Burner top hat that displaces the gas is dirty.
Remove the metal rack to expose the burner itself. Make sure it's not been used recently to prevent a burn. Carefully lift the little burner cap off. This is the piece with all the holes in it the flames come from. They generally just sit on top. You will need a flashlight, know look in the little slits below the cap for cleaning material buildup. A tooth pick or a stiff bristle tooth brush can be used to clean these little slits.
The cleaning products used to clean stove tops tends to leave little trace amounts of surfactants that over time block these little slits and prevent the escaping gas to flow towards the ignitor preventing the burner from lighting.
Once you have this clean replace the top. Put the pan grate back on and try to relight the stove.
I am sure this should fix you issue. If it doesn't please let me know and I can give you some other tips to try.
DR Wilkins
Oct 16, 2013 | Jenn-Air Cooktops
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
Badly stained gray burner grates for stove
Common problem, very frustrating...Use the self clean feature of your oven if available or you can place all of the grates and pieces into a black trash bag, spray them with oven cleaner and let the closed bag sit in the sun for a while, rinse and spot clean. You can get the tough stuff by "gently" using a steel wool pad - be careful, you could scratch the surface.
Aug 08, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
I have a Garland gas stove built around 1920. I need someone to tell me how to adjust the burners.
Hi there. When you say "adjust the burners", I am going to guess how to adjust the air setting? or are you looking for some other correction, problem fix, etc..
If you simply need to clean/adjust the air shutters, the easiest way to do this is, take the top grates off, now you should see your pilots, and the burner itself. You will lift the big end that is the burner, and carefully remove it off of the orifice on the valve you use to turn the burner on/off with. On the end that was over the orifice there will be a shutter that can get closed, clogged with dust, and affects the burner. set it about half way open, clean the dust out of it, and reassemble, that's it. If you are wanting something more, please comment. Thank you.
Feb 20, 2009 | Garland H283 Gas Kitchen Range
Slippery burner grates
hi thanks for the question i would contact the store you bought the new stove from and ask if they have a none slip grate thanks the appliance doc
Aug 25, 2008 | Tappan TGF320 Gas Kitchen Range
Should I???
Make sure that you will be happy with this unit. The ovens are fairly small and you will have to bend alot to use the lower oven. The only problems my company have run into so far are the control boards and not getting very clean following the self clean cycles. Good Luck
Mar 31, 2008 | Jenn-Air JDR8895AA Dual Fuel (Electric and...
Cleaning and care for my GE Profile stovetop
The one thing I don't suggest is using the Ceramabryte product the dealer left with us. It leaves a greasy film. When I get ready to clean my black GE Profile, I pull off the controls to wash separately. Then I lift off the grates, take a single-edge razor blade to scrape anything stuck on (it doesn't scratch), then I use baking soda and scrub and scrub with lots of paper towels. Then I start cleaning off the baking soda with lots and lots more paper towels. There is still a film, but at least it's not greasy. At this point I grab some more dry paper towels, pour on a 3' puddle of rubbing alcohol and wipe it all over the stove top and front. You may have to do this twice. Then, if I don't turn on the hood light's brightest setting, it really doesn't look too bad. I have to do this at least once a week, as I have never had a stove that got so dirty so fast and was such a pain to clean.
FYI, I would never buy another of these stoves. Besides the cleaning issue, there is the fact of having to replace the igniter (glow plug?) twice in the first four years. My old, bottom-of-the line Magic Chef went 25 years with the first replacement not coming until it was about 15 years old. Also, the broiler is unimpressive and steaks, etc., just sort of steam. Can't get a really good crust going. It's a slide-in and the top is very narrow, front to back, because of the slanted control panel on the front, and so you really can't put two large pots or pans on one side. Let's see....oh yes, I ordered the unglazed grates for safety reasons and it came with the procelain glaze. Those were replaced free of charge, though I had to go pick them up. Then the first set of unglazed grates began to rust about six months into use, so had to be replaced (again, no charge at least). Recently I noticed that the inside walls of the oven, where the racks slide, are starting to rust. Finally, the burners are difficult to calibrate, which I really notice when I try to cook rice, which comes out right about 50% of the time.
Now, on top of all this, I have to worry about the glass door exploding?!?! Should I ban my grandchildren from the kitchen? Has anyone from Consumer Reports seen this website?
Feb 01, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
266 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
