Question about Teac R2 Clock Radio
Backlight display does not light up
I bought the unit new from ebay, everything works except the backlight. Any ideas how to troubleshoot or repair?
0 characters
1 Points
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
Can't read fuction
Check the backlight LED voltage to display unit.
Mar 28, 2012 | RCA RP3721 Clock Radio
How do you increase the volume of the backlit light?
The backlight can be adjusted as follows:
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
Apr 07, 2011 | Timex T311T Clock Radio
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
Jul 08, 2010 | iHome Ih8 Dual Alarm Clock Radio For Ipod...
I have a Bose radio AWR1-1W and the display does not work I have replaced the battery and it still shows everything and I can not turn the radio on or off. Do you have any ideas
I would send the unit in to Bose. They have a flat rate repair service and they offer trade in value if you want to upgrade to a newer model. quoted from
  • Call 1-800-999-2673 to obtain a Return Material Authorization (RMA) number. This number helps us quickly track the status of your return
  • Pack the product in its original box. If you do not have the original box, mention this to the customer service representative when you call
  • Write the RMA number clearly on the outside of the box
  • Be sure to use a package-shipping service such as United Parcel Service, Federal Express or the United States Postal Service that is able to track shipments. Ship the package to:
    • Bose Corporation
    • Returns and Exchanges
    • 2000 Carolina Pines Drive
    • Blythewood, SC 29016
    • ATTN: RMA# __________
  • May 03, 2010 | Bose Wave Radio
    LCD light has gone out
    You will need to send it back to the manufacturer for repair for this. No doubt the LCD backlight has either burnt out of has a bad soldier connection inside. This can also happen if the unit has been dropped.
    Good Luck,
    Dec 12, 2007 | Memorex MC7101 Clock Radio
    Timex t439s clock display light out
    The display on my clock is red as well. I found it that way when I came home from work today. It had lost all of its settings as well. I put everything back to the way it was supposed to be but I can't get the color to change. I guess something just quit.
    Dec 12, 2007 | Timex (T439S) Clock Radio
    Backlight LCD adjustment possible? Owner's Manual?
    The backlight comes on automatically when plugged in and 3 seconds after the talk bar is pushed if the unit is operating on battery. The colors are based on temperature
    Mar 23, 2007 | Sharper Image MI602 Clock Radio
    Here is the link to the user manual; They do not mention any backlight feature in the manual - looking at other similar models, they describe the procedure in the manual - you just have to press the snooze button to turn it on or off. might be worth a try. reading reviews of the clock there is supposed to be a blue backlight feature - try pressing display when in radio or cd mode and you should get a menu of display options - i imagine one of these will allow you to select backlight on/off If none of the above works then try contacting them directly (numbers are in the manual) check this link if you want more info as they are recently bought out) Hope this helps :)
    Mar 10, 2007 | Sharper Image GT113 Clock Radio
    Teac R2 Clock Radio Logo
    55 people viewed this question
    Top Teac Clock Radios Experts
    Jim Parker
    Jim Parker
    ray gallant
    Are you a Teac Clock Radio Expert? Answer questions, earn points and help others
