Question about Amana ATB2135HR Top Freezer Refrigerator
I have a frigadaire electrolux refigerator tha does not closes tight on the ice box bottom. when you close it; it pops back open slightly on the ice box sweats and leaves water in the ice box. if this contiune to happen all my fod will eventionly while spoil. need a solution. it seems to either be the black plastic/rubber stipping or the the bottom snap in breathing plastic peice. thanks
  • 77 Answers
Replace the freezer gasket
Posted on Nov 15, 2009
My Electrolux side-by-side refigerator automatically started dispensing ice cubes in the middle of the night and would not stop until I manually pulled the lever to the stop position. It did this on 2
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Aug 29, 2012 | Electrolux E23CS78HSS Side by Side...
Refigerator door doesn't stay sealed shut
Check the seal condition for any damage, crack and etc. Ensure you check the whole seal. Clean the surface (seal and the contact) from any dirt/oil and etc.
Sep 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
Seal around door is not tight. there are no breaks in the seal but the door doesn't seal properly. you have to make sure that you close the door tightly and when you close the freezer door it causes the...
Is this unit new? Is it new to you? Has this problem just developed? I need the history to help you. If it is new, you have a year warranty. All units built today are as air tight as possible. When one door is opened and closed. The other door can pop open. To alleviate this issue the unit's front levelers must be adjusted to tilt the unit back slightly. The door or doors might still pop open but will close by themselves. If I can help you futher, let me know.
Mar 30, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
Recently purchyased electrolux 3 door . Had water supply disconnected for approx 8 hrs and now have water back on but ice maker will not make ice
You have to open the water hose let the water drain for at list 2 to3 minute so you can have the water line free with air package, and close backthe water hose
Oct 24, 2010 | Electrolux EI28BS56IS (278 cu ft) Bottom...
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Display screen says "Er ff"
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Jan 20, 2008 | LG LFX25960ST Stainless Steel French Door...
Amana ATB2135HR Top Freezer Refrigerator Logo
76 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
