Question about RCA R52WH73 Projection Television
RCA R52WH74 PIC IS DISTORTED LIKE HOUR GLASS FROM LEFT TO RIGHT AND COLORS ARE MISALIGNED SO YOU GET 3 IMAGES OFFSET FROM EACH OTHER IN DIFF COLORS
  • RCA Master
  • 8,617 Answers
The ITC222 convergence option missing repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the parts and the CD with instructions.
Posted on Nov 15, 2009
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
MY RCA MODEL R52WH74 YEAR 2006 PICTURE STARTED SHOWING 3 D IMAGING IN RED BLUE AND GREEN ,HOW CAN I FIX IT ???
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=S6Wa8FvSz-s
Aug 29, 2010 | RCA R52WH73 Projection Television
I have a HDTV 524159 RCA, it has an hour-glass effect on both directions. On the left side, it hour-glass inward with red and yellow stripes and on right side blue and light blue stripes. It hour-glass...
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 that will shut itself off
Replace 3 capacitors on Deflection board its the bottom left hand side cp150 200uf 16v use 25v capacitor and cp114 cp120 in same circuit 220uf 35v. You will see cap cp150 if it is puffed up on top they are Bad. Call Mats Electronis 1-800-628-1118 Radio shack might have capacitors.
Dec 29, 2009 | RCA R52WH73 Projection Television
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Rca r52wh74 projection 52" tv
Convergence in this unit can be one of 3 possible boards. can you adjust any ...do the crosshairs move in customer setup convergence menu
Jan 04, 2008 | RCA HD52W58 52" TV
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Sony DSC W70 Problem
You will need to describe what you see on the LCD in more detail in order for me to tell you what the problem is. There are two different issues that can cause things like what you are seeing. 1: Cracked LCD. You will see lines which resemble cracked glass. You will see bright vivid colors with specks of black or stark white all over. The image problems may be only in one portion of the screen. The LCD is made of glass, so if you look closely and see patterns that look like broken glass - this is your issue. Replace the LCD. 2: Bad LCD connection. You will see distorted colors, the screen may blank out and flicker when you shake the camera or press on the housing near the screen. If neither of these describe what you are seeing, post back and give more details and I will respond further. David Millier Advance Camera Repair
Feb 21, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
RCA R52WH73 Projection Television Logo
323 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
