Question about Motorola Mobility i850 Cellular Phone
Switched to a newer phone and then switched back how do i get my bookmarks back.. mbuzzy inparticular
How do you delete bookmarks and starred on iPhone 4?
  1. Select "Menu" > "Bookmarks".
  2. Select the star at the bottom of the screen. This will show you your "Mobile bookmarks", which are the only bookmarks you can edit or delete from your mobile device.
  3. Tap and hold the bookmark you wish to edit or delete.
  4. A menu appears.
Mar 23, 2016 | Cell Phones
Tip
Creative Zen V Plus Bookmarks
A little known feature on this player is the ability to use bookmarks, up to 10 of them. Many of you listen to podcasts or audio books which may be fairly lengthy and if you have to stop in the middle of what ever you're listening to, normally when you go back to your player you would have to start all over again.<br /><br />A note about <span style="font-style: italic;">"resuming playback":</span> If you shutdown during playback of a podcast or audio book (not pausing or stopping playback first) your Zen will automatically resume playback when you start it back up.<br /><br /><span style="font-weight: bold;">Zen V Plus Bookmarking</span><br /><br />You can insert bookmarks during playback. A bookmark helps you mark a point within a track, so you can return to it at a later time.<br /><br />You can use up to 10 bookmarks at any one time.<br /><br /><span style="font-weight: bold;">To insert a bookmark:</span><br /> <ol> <li>In the Now Playing screen, press the Options button and select Set Bookmark .</li> <li>For ZEN V Plus, you will need to press and <span style="text-decoration: underline;">hold</span> the Options button. Playback pauses and the Set Bookmark screen appears.</li> <li>Select a bookmark number.</li> <li>Your bookmark is assigned to the selected bookmark number. If all 10 bookmark numbers have been assigned, you can replace an existing bookmark with the new one or you can delete a previous bookmark.</li></ol><span style="font-weight: bold;">To delete a bookmark:</span><br /><br /> <ol> <li>Press and hold the Menu/Back button. The main menu appears.</li> <li>Select Music Library and then Bookmarks .</li> <li>Go to the bookmark that you want to delete.</li> <li>Press the Options button. For ZEN V Plus, you will need to press and hold the Options button.</li> <li>Select Clear Bookmark.<br /></li></ol><span style="font-weight: bold;">To go to a bookmark:</span><br /> <ol> <li>1. Press and hold the Menu/Back button. The main menu appears.</li> <li>2. Select Music Library and then Bookmarks .</li> <li>3. Select the bookmark that you want.</li></ol>Note: The Bookmark feature is not applicable for contents played from the memory card for players such as ZEN 2GB,4GB,8GB,16GB, 32GB and the ZEN X-Fi Series. ZEN Xtra also supports bookmarks though you cannot place two or more bookmarks for one song or audio book<br /><br />
on Jan 25, 2011 | Creative Labs ZEN V Plus MP3 Player
How do I restore my mozilla firefox bookmarks
Try to login with your gmail account. Or open your gmail account which you always use. Some time it will recover back your bookmarks
Feb 14, 2015 | Mozilla Firefox
How do i contact firefox with a question ?
Multirow Toolbar is outdated and does not work with newer Firefox versions. There is a "Multirow Bookmarks Toolbar Plus " version, but if you check the comments, many people complain about the same issue.
Try this one instead: Roomy Bookmarks Toolbar
Oct 23, 2014 | Computers & Internet
How do I delete top hits and Bookmarks from iPhone5??
You will need to delete your browser cache to remove top hits.
To clear the browser cache:
From the Home screen, choose Settings > Safari. Tap Clear Cache.
To delete bookmarks:
Open any webpage in Safari and then tap the bookmark icon at the bottom of the browser. Once the Bookmarks window shows, tap on the edit button at the bottom right. The bookmarks will then show a red delete icon next to them. Tap the icon to delete the bookmark.
Hope that helps!
Oct 09, 2014 | Apple iPhone 5
How to delete a bookmark on the phone
the bookmark option will be in webapp. select bookmark and manage your bookmark..
Aug 05, 2011 | Cell Phones
No longer holds a bookmark
I've had my MuVo V100 for a year and can tell you it only saves the bookmark for the last file played. Hence, if you're into a long audiobook, don't switch to another. I've taken to making note of where I am because if the battery dies while playing it will also go back to the last saved bookmark.
TIP: if you accidentally switch away from a book you're listening to, pull the battery BEFORE turning it off -- it will revert to your last bookmark.
my 2 cents
Jan 20, 2008 | Creative Labs Muvo V100 MP3 Player
Motorola Mobility i850 Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
