Question about Cell Phones
Need to rewire and attach plug and base boost are there wiring diagrams available? Skullcandy skullcrusher
Wiring for briggs stratton 6 hp law mower
no need single non grounded wire from spark plug or follow plug wire to its base the may be a place for attachment then attach the other end to a non grounded switch wired to the frame (to frame this is a ground ) when wire is grounded to the frame or engine the spark plug will lose power and motor will stop un grounding will allow to restart this is ussualy done by the bar you hold down on the handle this is a by pass or help you understand how to rewire the handle but it may not be the wire but the handle or its cable or where the cable conncets i dont recomend children using machine after this has been done even with help this has made the machine more dangerous not to stop when you let go if using bypass
Oct 14, 2014 | Garden
How to rewire a GE 75423 electric fan
Four wires coming from base to motor. I need a diagram of which wires connect to the electrical components in the base.
Aug 26, 2012 | Dryers
The bass vibration suddenly stopped working I changed the battery turned the music up loud and still mo vibration. I constantly have the bass on Max, and if that is the problem then skullcandy should not...
Sounds like you blew out the sub-woofer in the headphones. You could replace them, or if you've only had them for a year (or less) you can use the warranty included and have them fix it. All you have to do is call them up and ship the headphones to them.
Their contact page is listed below:
http://www.skullcandy.com/contact-us.html
May 17, 2011 | Skull Candy Skullcandy Skullcrushers...
The metal piece(miniplug) too my Skullcandy Skullcrushers has come off completely from the plug at the end, most likely snapped from ware and tear. What can I do?
See my tip on headphone plug/cable problems. Also you may have to seek out the correct plug if it doesn't match the type shown in the tip.
Aug 10, 2010 | Audio Players & Recorders
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Jul 02, 2010 | Drills
Skullcrusher Bass not working.
You might want to check out my tip on replacing dodgy cable/plugs on headphones.
May 13, 2010 | Skull Candy Skullcrushers Headphones
Jack in the headphones fell out?
See my tip on replacing dodgy cables and plugs on headphones.
Apr 25, 2010 | Skull Candy Skullcrushers Headphones
I had bent my skullcandy skullcrushers 3.5 mm jack and i dont know what to do and my left headphone is the only one working
What you need to do is cutt off the old 3.5mm jack and buy a new one. Cutt it off 10cm from the end of the plug (this is so you clear any weak or damaged area).
The new plug will have two lugs (one small and one bigger) and a large metal flange with a T piece flange on the end. Strip back the wire on the cable, you should see two coloured wires and some earth wires. The two coloured wires need to be soldered to the two lugs (left & right) if you get the channels the wrong way reverse them it wont hurt the headphones. The earth wires (all) solder on the large flange. Don't let solder or wires from the L&R touch the earths or each other. The T part grips the the black cable to prevent it being pulled. Bend the T to grip it. The Body of the plug should be put on the wire before you attach the rest of the plug. Slide it over the plug when done.
If the sound seems 'spaced' out then an earth wire is not connecting right to the metal flange.
Apr 07, 2010 | Sony MDR-V700DJ Professional Headphones
Need to rewire electrical system. need diagram.
Check out faxon auto literature. They list the original VW service manual for your car.It should have the wiring diagram that you need but you could confirm that with them before you bought it. I've used them befor and had excellent service. Hope this helps.
Jan 11, 2010 | Volkswagen Beetle Cars & Trucks
Bass amplifier doesn't work even when i switched the batteries.
The bass unit must be defective. Talk to the guys at Skullcandy for a replacement (they offer lifetime warranties for stuff like this).
Their website has a link directly to the warranty page as well: www.skullcandy.com/warranty
Hope this helps
Apr 14, 2009 | Skull Candy Skullcrushers Headset
Cell Phones Logo
215 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
