Cannot connect to internet via wireless hub to laptop
  • 32,281 Answers
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable modem.
To check if the modem is configured to your ISP settings and connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can connect to the Internet.
Next, the wireless router needs the wireless settings configured and then configure the wireless card in the laptop with these settings so it can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Posted on Nov 14, 2009
Pc to laptop
If you want to connect a pc (desktop?) to a laptop you need a network of some sort.
This can be via various methods.
1. USB cross connected Cable between the two machines.
2. Network connection via a hub, server or switch. Both sides have to have an IP address.
3. Over a wireless connection, as above the pc would be connected to the router and the pc laptop could log-in to the router with appropriate password to connect together using IP addresses.
4. Over the Internet if not in same room. (FTP protocol to send files between the two computers.).
Jan 19, 2014 | Computers & Internet
My samsung r519 has stopped connecting to the internet
Does the Laptop say it is connected to your wireless router? If not, connect to your router. Maybe the laptop is continuously polling because you keyed the Wireless Network Key/Password in wrong. If it's wrong, it will never connect.
Try disabling the wireless connection, then enable it and see if it connects and lets you out to the internet.
Make sure you are using the same Authentication (None, WEP, WPA, WPA2) as the laptops that you say work.
Apr 08, 2012 | Samsung R519-53S Notebook
We cannot connect wirelassly
...I'm not sure on what your actual question is here but make sure you have a wireless network to connect to (you can buy wireless router and an internet service via any internet service provider- I use BT)
If that's not your problem (which i don't know what is) - then make sure your typing security WPA key in properly. (WPA key should be located on the back of your router/hub if that wireless hub got delivered by your current internet service provider). If your still having trouble contact your current home network manager (dad/mum/guardian/employer/lanlord) who has software to control the WPA & what it is).
Your xbox should have a network adapter already installed (device inside that allows connection wirelessly to a networks wireless router/hub). So that shoulden't be the problem (unless your xbox is broken)
Apr 11, 2010 | Sony Playstation 3 (PS3) Console
Can I connect my HP PSC1510 to my BT Homehub v1?
yes, you can. I have my printer connect to my hub and my desktop and I can print from my laptop wirelessly.
You will need your all in one connected via a printer or USB cable to a computer AND also connected to your hub. Then, go to the computer that is connected through a cable to the all in one. Your all in one should have some way to configure its IP address. I have my printer configured as 192.168.1.4 and it's plugged into the 4th port of my hub. Check if this works.
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
How can i connect a wireless internet connection with a compaq armada E500
Get a PCMCIA to USB2 adapter that has an external 5 Volt connection to it to supply the higher current for the wireless adapter. The power can come from the USB via USB adapter cable
After installing the adapter, the USB wireless device should be installed just like in any later notebook. The wireless device requires USB2 and high power. and won't work off a powered hub.
Feb 05, 2010 | Compaq Armada E500 Notebook
My hp pavilion dv 9000 can not connect to bt home hub 2.0
hi, please make sure that you enable WPA encryption on the wireless router. Vista will give you trouble if you use WEP encryption. Also, please update the firmware on the wireless router, if possible.
Let me know how it goes.
Oct 26, 2009 | Computers & Internet
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
How to add Wirless & Ethernet connections?
The only difference in using a wireless hub is that it will go between your router and your computer. The advantage is you can take your computer anywhere within range and connect using your computers wireless card (if you have one).
You won't need any more equipment or memory and most wireless hubs come with instructions. If they didn't give them to you, just Google the manufacturer and model of the hub and you should be able to find them easily.
After you've set up the wireless hub (which you can still connect to via your ethernet cable). your computer should notify you of wireless networks available. You have a utility to set this up within the control panel.
Let me know if this helps
Dec 21, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
