Control board on a weatherking package unit (gas) is coding with 5 flashes. What does it mean?
  • 89 Answers
I think that is not detecting a flame code. There should be a code listing on the inside of panel.
Posted on Nov 17, 2009
Testimonial: "your right! The limit switch was defective. Thanks for your help..."
I have a kenmore portable ac 12000 btu model number on the side says 35132 i have a serail 351321102073 i have a e3 code displayed what does that mean?
The E3 F1 error code indicates a Fuel Type Failure. The control board on the Kenmore ranges and ovens that use this error code can detect whether the control board programming is set for electric (E) or gas (9). The troubleshooting for this failure is to unplug the range or shut off the breaker to completely kill power for 30 seconds. After powering the unit back up, hold the CANCEL and START/ENTER keys for 5 seconds. You should see "E" for electric or "9" for gas. If you have an gas range and the "E" is showing for electric, then the electronic oven control board will likely need to be replaced. The opposite is true if you have a gas range or oven.
Jun 13, 2017 | Kenmore Heating & Cooling
What is the meaning of timer flashing twice in the indoor unit of fujitsu heatpump astb24ldc?
Need to check that models error codes but for most Fujitsu A/C's, that means a "serial signal reverse error at start up" which means your outdoor controller board is stuffed. Try turning the main power switch off for 5 minutes and then back on. If the error persists, you will need a new controller.
May 06, 2015 | Fujitsu Heating & Cooling
Rheem heat pump not coming on in heat mode. Control board has two LED lights # 1 solid, #2 blinking. What does this mean?
Usually wen the led lights are blinking it means there is a problem. If you look on the door or the cover there should be a code that tells you what the blinking represents.
Example - one blink per second - compressor, two blinks - fan motor, etc. The other thing you can do is look up the model number on line for the installation manual and it should have all the info you need.
Jan 08, 2015 | Ruud Defrost Control Board 47-102684-08...
I have a Amana unit Model# PGA60C1152F that has a blinking light on the control board it blinks 4 times. That heat will come on then go off but the blower nevers comes on.
look on the inside of the door that you took off and there should be a diagram and on that there will flash code that will tell you what 4 flashes means.i think it is a flame rollout or high limit.
Nov 16, 2012 | Amana Heating & Cooling
I have a Braemar LCB450-G evaporative cooler. There are two Diagnostic LED,s on the electrinics module,one red & one green. When the power is turned on at the module the red LED remains on & the...
There are several possibilities, the drain valve is opening and closing, this causes water to fill the base, the float valve will not achieve the desired level so the fan will not start. This could be the drain valve actuator is U/S or the PC board. Have you tried to turn the main power off at the switch board for 1/2 hour?
Most occasions the service person will swap out all the units as they purchase it as a package. It is not cheap to replace these units.
Nov 22, 2010 | Heating & Cooling
My Amana asx 16 seer 4 ton system installed 3 years ago quit working. The alert light is flashing 6 times. What does this mean?
Hi if you are looking at the indoor unit and this is where you see this flashing light, remove the panel. The circuit board is where this led light is. You will also have a 3 to 5 amp fuse plugged into the board. Look for a chart on a panel door. It will be glued there. It will tell you what the problem is according to how many times it flashes. Could be several different safety switches. Make sure there is no door panel switch on the indoor unit, has if there is, the unit will not run after you remove the panel, it kills power to it. You may need to tape it down so you can have power to run it and check it out. Is the indoor unit a gas system or is it a 4 ton heat-pump? If you cant find what I have said, get back to me after checking these things and let me know . Check all breakers. Let me know if this is a package unit or a split, indoor and outdoor unit, or all in one. I will wait to hear back from you on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jun 29, 2010 | Heating & Cooling
F1 flashing on gas stove-manual says to push clear-where is clear button
HI. This actual code cannot be cleared by pushing the Clear/off button. This actual button will usually be located on the touch pad and is a basic cancel button. You can try to reset the entire control board by simply unplugging the unit for 5 minutes. This may correct the issue. If resetting dose not correct this fault, the necessary actions are to have the defective main PCB replaced, asap.
F1 - Defective control board(PCB)
May 23, 2010 | Frigidaire FGB24S5A Gas Single Oven
I have just replaced my HVAC Control board &
Once you have installed the jumper, you will need to kill power to the furnace for about a minute to reset the board. Make sure the the jumper is making good contact. Sometimes they appear to be plugged in but still are not making contact.
Oct 04, 2009 | Heating & Cooling
Weatherking control board
the fan comes on only after the burner fires. so no stat voltage is expected. it is not powering the blower, the elec board is. only after burner lights will fan be energized due to heat build up. usually on older weatherking there is a heat sensor on the bulhead above the burners. it is stuck sounds like to me. try a sharp rap on the right side about four feet up the side and a foot back . if fan stops you know the switch was stuck . probably needs a new fan switch.
Oct 20, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
