Question about Mitsubishi WD-57732 Projection Television
Replaced lamp on WD57731. green light turns on then a ornage light, under lamp blinks
  • 10,594 Answers
Please put back lamp cover, the last plastic grille that were removed to replace lamp in TV.
TV sense that lamp cover is not either put back or not fixed properly so it wont turn On. Check lamp cover and problem will be solved.
Thanks.
Posted on Nov 14, 2009
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Questions?
Mar 12, 2012 | Mitsubishi WD-65735 Television
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Replaced bulb for Vizio rp56 DLP got power no light
There are interlocks that will prevent the set from starting if the lamp is not installed correctly or if the access door is not closed properly. Either condition will result in a "lamp error" indication. Try reinstalling the lamp being careful to be suer that it is seated properly. Also make sure that the access door is fully closed and aligned. If you continue to get the lamp error, it is possible that the ballast circuit is defective. This is the part that generates the power to "fire" the lamp.
Keep us posted.
Dan
Mar 10, 2009 | V, Inc. VIZIO RP56 Rear Projection...
DLP Lamp Replacement
yes it is in a cartridge and it is plug and play. and if 1 year old still under wtty. The dimness could also be your fluids??
Apr 01, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Wd57731 won't power up
Have you checked the air filter? Did the set operate normally after replacing the lamp?
Mar 12, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi WD-57732 Projection Television Logo
296 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
