HP G6000 Optical Disk Drive malfunction
Hello
I have an HP G6000 laptop and the DVD rewriter drive isn't functioning. It stopped working mid-Dvd watching and since then has either refused to switch on or when I do manage to keep it on long enough it doesn't make the normal noise when it's spinning the cd then just cuts out again.
The drive is listed in the device manager but instead of being listed as a CD/DVD drive it is listed as a disk drive.
I have uninstalled the drive, updated drivers, uninstalled and reinstalled drivers but had no luck in fixing it.
Any ideas what I should do next?
Thanks so much
  • 3 Answers
It sounds like you have done just about everything. The only thing you might do is try a CD cleaning disc (which has fine bristles to clean the optic sensor). Other than that, you've been very thorough and probably should think about replacing the drive. Hope this helps, Best Regards, -md
Posted on Nov 14, 2009
Replace an optical drive
depending on model it is usual that there is a removal tab one one edge of your drive face. press this in and the removal tab should be visible then pull to remove the drive from the laptop. (do this when power is off)
order replacement of drive and insert into slot.
I hope this was useful.
Feb 25, 2013 | Computers & Internet
Will the rm475e work with a Mac?
May 16, 2015 • Yes I was pleased to find that indeed the HP rm475e works wonderfully on my mid-2009 MacBook with OS X 9.5 Mavericks, where the internal optical drive is not functioning properly! Its Mac compatibility is not mentioned anywhere in the requirements schematics on the original packaged box either ... how odd, huh! LSDexitOzAmericaDotOrg
Aug 06, 2011 | HEWLETT-PACKARD HP 8X DVDROM 24X CDROM USB...
HP Pavillion laptop won't backup to optical drive...CD/DVD-RW; I do have 1 Click Copy (&Pro) installed as well as DVD43. I have tried to uninstall the DVD43 & 1 Click but it doesn't change...
HP Pavillion laptops and every others laptops do require CD/DVD recordable for backup not CD/DVD rewritable. Try to use a CD/DVD recordable to see what will happen first.
Sep 16, 2009 | HP Computers & Internet
DVD Drive reads CD's but wont read any DVD's
Let me explain some things for you to understand what happened with the dvd drive.
A laptop (or desktop) dvd writter drive is actually build around 2 separate optical systems each specialised to deal with either a cd or a dvd type of disk.
A cd has normally around 650mb - 700mb.
A dvd has normally around 4,3gb - 4,7 gb.
But both disks have the sime size. So the larger capacity disk, the dvd has higher data density as related to the disk surface. Therefore because these disks are being read using laser diodes, each diode must be tuned to a specific frequency for each type of disk. A cd is read/written by a 860 nm diode (infrared) and a dvd is read written by a 630 nm diode (red). These are separate optic subcomponents (by the way, a blue ray disk and reader is called blue ray because of the diode that is used to read them, it's on 437nm and it's emitting blue light).
If your drive will read only cd's and fail to read a dvd then it means that the coresponding optic block for dvd reading has failed. The cd optic system will continue to function as it's not linked to the dvd part.
In this situations there is little to do to save your drive so you should consider the replacement or assistance in a service center for your problem. I'm sorry as we aren't able to fix this without having to dissasemble things and use some service equipment.
May 22, 2009 | HP Compaq nx8220 Notebook
Disk drive malfunction(cant read or write disk)
i fu got help from me by my solution in other problem pls rate me FIXYA if u like
Apr 02, 2009 | Sony VAIO VGN-N110G/W Notebook
My dvd writer showing a rewriteable dvd as an empty dvd,but it's not empty..
Its the problem with your dvd disk but not the Drive.
Make sure the disk doesnt have many strikes or dirt.
Normally Re-Writables dont work if they have heavy strikes.
Mar 31, 2009 | HP (344542-005) DVD Drive
HP CD/DVD optical drive is not recognized
I found that there was a firmware conflict caused by the installation of iTUNES. I uninstalled and cleared the upper and lower filters in the registry and the internal DVD-Rom is recognized. First I cleared the registry and the drive was recognized after a hard boot. So Far no twitches. Knock on wood.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
534 people viewed this question
David Payne
David Payne
