Question about Samsung CLP 300 Laser Printer
My samsung cpl300 is not feeding sheets at all. it stops short and a message comes up saying"paper jam...check the exit..." but there is no jam, as it never takes any sheet in. what do I do to fix this.
Most likely there is a small piece of paper caught at one ont the sensors. Make sure you look very carefully and get every last piece out.
Posted on Nov 18, 2009
Samsung clx-3150 paper jam. it will only feed 20wt paper from bottom tray. anything else stops and i get a paper jam 0 error message
Check the specs operators manual or go to the Samsung web site look up the specs for your machine. The weight of your paper may be greater then the machine can handle.
Nov 17, 2015 | Samsung Office Equipment & Supplies
A sheet of paper keeps getting jammed - we remove it and try again but it keeps jamming. We have cleaned the rollers inside where the cartridge goes and it did not help
If the first sheet of paper is correctly feeded and it shows up after fusing unit and that happends every time, then probably you have damaged exit paper sensor. It have to be replaced with new one.
If the paper feeds only few santimetres then you have to replace paper feed roller
pifonski
Feb 23, 2011 | Samsung Office Equipment & Supplies
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
Apr 16, 2009 | Canon DR-5010C Scanner
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Printer Jam - when i put a sheet of Avery labels, printer jams
When you say TOP TRAY, do you mean a paper drawer, or the BYPASS TRAY? If the labels won't feed into the bypass but bond paper does, check to see if your labels are made for inkjet printers. Go to www.avery.com and contact Avery customer support to see what product they recommend for your MFC. Labels made for plain paper printers sometimes do not work for inkjets, and vice-a-versa.
Aug 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam error message
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery with age, and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it). And then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Dec 28, 2007 | Canon PIXMA iP1600 Printer
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
252 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
