Question about LG VX5500 Cell Phone
Display has gone out
My display, both front and inside, went completely white last night and hasn't gotten any better. I've turned it off and on, taken out the battery and put it back; no difference. The phone itself still works fine - I can still receive calls and even make them, although that's a little tricky - just no display. Is this going to fix itself?
WHY IS MY SCREEN STUCK ON WHITE?HOW DO I FIX IT?
move on to near by service center if u have valid warranty..
might b issue with the ROM OR DISPLAY problem..if its display, replace with the new one..if its ROM then they will flash and give u
Oct 17, 2017 | Cell Phones
I have an acer aspire 3000 I logged off last night and today went to turn it on it powers up but it won't display anything just a black screen
I think your OS might have gone..... So try installing an OS CD in it and see if it displays something or not. If not then your display is gone. You have to repair it in a repairing shop.
Jun 09, 2013 | Computers & Internet
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Won't charge or turn on
maybe the problem was your battery, i just think that youve overcharged it. try to replace another battery. hope that helps!
CHARCOIS
dont forget to rate my post thanks!
Jul 27, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Display on LG VX8600 screwy
well most probably your lcd screen is fualty you can fix this yourself with a t6 torx screwdriver and a new lcd screwdriver that will cost you around 15 pound on ebay , hope i helped
Oct 17, 2007 | LG Chocolate Clamshell VX8600 Cellular...
Big Problem
Hi Nvidiot, Sounds like the backlight inverter board. It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 23, 2006 | ViewSonic VX924 19" LCD Monitor
LG VX5500 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
