Question about Motorola Mobility i880 Cellular Phone
I have an i880. My phone was not set up to save my pictures to the memory card. Is there a way to save them to the card or do I need/or can I download them on my computer using a usb?
How to save a picture on a i68+ touch screen phone
Hi friend,
Could you tell me where are the pictures from that you want to save? From MMS? Bluetooth? Or you downloaded from computer? If you want to save the pictures, you'd better insert a memory card in your cell phone, for the storage space of your cell phone is limited.
If you want to save the pictures that from the MMS, you'd better check if your cell phone itself has much enough storage space, sometimes, your cell phone can only save a certain amount pictures,if there doesn't have enough storage space, you'd better delete some.Or may be you can save them to the cell phone or the memory card (May be you can set the storage space when you receive from others,that depends on your cell phone).
If you want to save the pictures from bluetooth, first, you may need to set it as the following:Bluetooth-Power on -Settings-FTP settings-Shared folder-Phone/Memory card(You'd better choose the one which has much more storage space)-Then choose the folder which you want to save the pictures in.
If you want to save the pictures that you downloaded from your computer, you may need...to get much more information, you can visit here:www.1010store.com
Have a good day!
Oct 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do you download pictures from this phone into computer so they can be printed out? Did not fix for save into card onlly save in phone.
there is a provision to select and copy from the phone memory to the card. do that and insert the card in the PC's card reader.
Oct 06, 2009 | Motorola Mobility i880 Cellular Phone
How do i download music from computer to my i880 and do i have to sync phone
Are you wanting the music for the MP3 Player? First of all you need to go to the media center in your phone menu and make sure you open a picture and then hit menu again click on remove the card. Once you get the message that says It is now safe to remove the card, remove your memory card, Your phone should have come with an adapter for your to insert into your computer, once you do this...it will open up the folders and then drag and drop music, pictures, etc to your phone but make sure you place music into the Audio file...the size of the memory card depends on the number of songs you can have on there.
Hope this helps!!
Apr 17, 2009 | Motorola Mobility i880 Cellular Phone
I lost all my photos after swapping simm card from i776 to i880. Is there any way to retrieve them? PLEEEAAASSSEE HHHEEELLPPP!!!!!!
Did you send any of them via picture mail? If so they should be saved on your carriers server depending on how long ago they were sent. Check your online account or contact your customer care department to find out the specifics of their picture mail site or database (e.g. www.sprint.com/picturemail for Sprint or Nextel accounts, Verizon's site seems to be down). If not, the sim card probably reset itself during the swap to match the software requirements of the new phone. If these don't assist then I am sorry to inform you that they are likely lost for good. In the future be sure to save your pictures to an external memory source such as a memory card or to send them to an email address prior to completing the swap. Also, I always recommend, having a sim card for every phone and keeping them with their respective devices. A store for your carrier can swap over any contacts after changing phones for you. Most carriers also sell an accessory that will swap info from one sim card to another. Hope this is at least helpful for the future if you arent able to locate your pictures. Good Luck!
Mar 29, 2009 | Motorola Mobility i880 Cellular Phone
Put music on card mp3 player i880 phone
You can use Windows Media Player's "Sync" function to transfer music from your music library to your phone, but you need a data cable to connect the phone to your computer, or you can use a USB memory card reader that allows the computer to see the memory card as if it were another drive. NOTE: The i880 can ONLY play music files in an .mp3 format; if they are in ANY other format, they will not even show up on the song list on the phone.
Mar 23, 2008 | Motorola Mobility i880 Cellular Phone
I880 Phone
You cannot copy music to your phone. It has to be saved on the card only.
Feb 25, 2008 | Motorola Mobility i880 Cellular Phone
Memory Card
yes you could , maybe you could have more than 10 if you dont have too many pictures or Phone contacts
Feb 24, 2008 | Motorola Mobility i880 Cellular Phone
Motorola i880 phone.
check that the write protection on the disc is not on its a little switch on the card
Dec 04, 2007 | Motorola Mobility i880 Cellular Phone
Motorola Mobility i880 Cellular Phone Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
