Question about GE 19GT270 19" TV
My GE 19GT270 TV turns on fine, runs about 20 minutes then goes to snow like there was no signal. The menu items still work, just with a snow background. Turning the TV off and on doesn't help, but it will turn on fine the next day and repeat the cycle. Help!
  • 541 Answers
These sets are famous for tuner problems. They develop loose connections at certain ground points around the tuner shield and inside the tuner. When the set gets warmed up the solder starts expanding and causing your problem. This can be a tedious repair. You may want to have a shop check it out for you. Thanks for using fixya.
Posted on Nov 19, 2009
Sharp 20 flat screen TV
if you go through a cable box, the box has to be reset or its bad.If it has a cable box, unplug from back of box and plug back in after 60 seconds and see if this works. Some boxes will count down to reset them
Sep 14, 2016 | Sharp Televison & Video
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
How to install DVD player on GE Model 19GT270 TV
To hook a DVD player to this model, you'll need an RF modulator (also called an RF converter). You can find one at most retailers where they sell TVs, and also online from places like Amazon.com.
Without the AV jacks, the only way the TV can pick up anything is with its tuner. An RF converter takes the audio and video signals from the DVD player and turns them into a channel 3 or 4 signal that the set can tune in. Unfortunately this does reduce the picture quality some, but on older TV sets it's the only option.
Sep 11, 2011 | GE 19GT270 19" TV
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
No start up menu
connect a hdmi lead, choose the right socket on the tv and this will work fine
Aug 01, 2009 | Sony PlayStation® 3 (80GB) Console
Blue screen on all channels RCA TruFlat
This is NOT the problem. video games, dvd player and cable connection are all all a blue screen with sound
May 14, 2008 | Televison & Video
Digital Converter Box
# 1. Why are you using a digital to anaolg box when you only have a analog signal coming in? The box is designed to see digital information then converting it back to analog. Please explain further what you are attemping to do?
Mar 28, 2008 | GE 19GT270 19" TV
Mitsubishi CS31305 TV turns on then goes to snow and then back on
snow basically is a symptom of weak signal.
as you say it becomes ok after 5 minutes or so there no question of any components gone wrong except loose or print intermittent
please check.
1  input weak like cable or antenna or loose wire from the source..
2  in tv antennae socket loose.
3  near tuner any thing loose or track loose.
4  cable wire might be old.
hope this will help.
Oct 09, 2007 | Televison & Video
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Horizonal White Line
Your problem could be one of the common ones as this set has loads of bad solder connections. Your problem is most likly the verticle output IC connections or the B+ feed componets have bad solder connection on them. In some cases though the Output IC is defective and will need to be repalce. if you have no soldid state repair or soldering skills play it safe and get a pro to assist you in this repair. It should not cost you more then a hundred bucks or so and thats the high end. good Luck, And Merry christmas.
Dec 25, 2006 | GE 19GT270 19" TV
GE 19GT270 19" TV Logo
52 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
