Question about Kitchen Ranges
Have a sipmson neptune stove and all 4 elements on top will only go on high, no matter what you havve the dial turned to.
  • rewa Nov 14, 2009
    No this is an old stove that has just started doing this, they are electric elements. About a month ago two of the elements only went on high but the other two were okay now all of a sudden they all go on high only.
  • rewa Nov 15, 2009
    Yes thanx
  • 434 Answers
I am guessing this is a new cooktop for you. The burners don't adjust like gas burners. they run full power, and turn on and off to regulate the heat. If you are noticing that the burners light up like they are on high, this is normal. They should light up and dim to regulate heat.
If this isn't the case and they just go straight to high and don't dim, the temperature switch in the back of the stove is bad. Hope this helps...
Posted on Nov 14, 2009
  • Mike Phillippi Nov 15, 2009
    Each burner is seperately controlled by an infinite heat control swith, or burner switch. This is the part the knob actually connects to. If they short out, you may be left with only low, only medium, only high, or it just won't work anymore. I tried to do a search to get a price for you, but couldn't find anything. Hope this helps...
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
The element on top of the stove stays on
Replace the switch for the bad element. It is stuck internally in the ON position.
Jul 30, 2009 | Frigidaire FEF352 Electric Kitchen Range
No operating instructions
the top one turns the broiler elements on 1 is for the center element 2 is for the 2 side elements and 3 is for all 3 elements. The next dial down turns the electric on or off . the third dial is the same as the top except for the bottom elements
Apr 11, 2009 | La Cornue Chateau 120 Dual Fuel (Electric...
Stove top elements on high only
Yarsu Spiros
I like you purchased one of these thinking you can trust the name simpson(pope) but after putting on a fry pan with sum saucages in and having a major fire in my kitchen, I through the heap of junk out and bought a *** oven (current technologie) howerver to answer your question you have pulled the elements and trays out to kleen them (that seems normal) but you need to make sure the element terminals are clean and so are the spring clip things they fit into, use a peice of emery cloth (not wet & dry) this should fix it
alternativly not buy this junk again and get a proper stove
regards Graeme
Auckland NZ
Jan 02, 2009 | Kitchen Ranges
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Electric stove
if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Apr 09, 2008 | Cooktops
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it...
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Apr 08, 2008 | Kitchen Ranges
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
