Question about Dell Dimension 8200 PC Desktop
4.0 GB of Spyware errors taking up space in my computer
After Disk Defragmentation I have the message: "Files that cannot be defragmented"...Fragments 65,541, File Size 4.00 GB, \Program Files\Microsoft AntiSpyware\errors.log
May I delete this file to help empty out my computer and speed it up?
    Master:
  • Dell Master
  • 956 Answers
Yes! it is the log of previous antispy ware scans.
Posted on Nov 14, 2009
Testimonial: "Thank you, made an immediate positive change to my computer speed!"
When I try to defrag my hard drive, I get a message which says "disk defragmenter could not open".
Possible Solutions:
1. Turn page file on.
Turning the page file on is a relatively simple process. Begin by selecting Start and right-clicking My Computer. Choose Properties and then press the Advanced tab. Next, choose the Settings button that is located in the Performance area; choose the Advanced tab in this area, and then press the Change button that is found in the Virtual Memory area. There will be a choice called System Managed Size in the Virtual Memory area, select it, press Set (this one is important), and then choose OK. The final move is the most important one; at this point you need to restart the PC. After you finish following these directions Disk Defragmenter should be available to do its magic.
2. Re-register the defragmenters snap-in files
It is possible that you install a third-party defragmenter like Diskeeper, then on uninstalling, it does not restore the built-in one correctly. Open Command Prompt (good ol' DOS) by clicking Start -> All Programs -> Accessories -> Command Prompt. At the command prompt type,
cd \windows\system32And then register the defrag components, by typing:
regsvr32 dfrgsnap.dll
regsvr32 dfrgui.dll
At this stage, you may find the disc defragmenter works. If not, there is one more step you can do.
Using Windows Explorer browse to your windows\inf folder.
In there you will find a file called dfrg.inf right click this file, and select Install.
3. Check if you have enough free space on the drive you want to defrag. It should have at least 15% free space.
A volume must have at least 15% free space for defrag to completely and adequately defragment it. Defrag uses this space as a sorting area for file fragments. If a volume has less than 15% free space, defrag will only partially defragment it. To increase the free space on a volume, delete unneeded files or move them to another disk.
4. Run CHKDSK on the volume first before defragmenting.
To run chkdsk on a volume (partition, disk), go to Windows Explorer (not to be confused with Internet Explorer) -> right click the partition -> Properties -> Tools tab -> Check now -> place check marks as required -> Start
5. Check if you have the appropriate services running.
Start > run > services.msc [enter]
Browse down to these services and see if appropriate settings was set.
Logical disk manager - automatic
Logical disk manager administrative service - manual or automatic
Defrag with XP also needs the DCOM Server Process Launcher service running.
6. Your computer might have spyware or malware. Some viruses/malware are known to interrupt/disable system tools such as disc defragmenter. Try to download and run No Adware (download here), an anti-spyware and adware tool. You can also use Malwarebytes Anti-Malware tool or Smitfraudfix (how to use smitfraudfix?) to remove spywares or malwares that are running on your system.
7. Install and run third-party disk defragmenting software.
8. If all of the above possible solutions fail. I'm afraid you need to repair install your OS or as a last resort, reformat your computer (but yeah, I know, nobody want to do that just because of disk defragmenter).
Jul 08, 2010 | Microsoft Windows XP Home Edition
Tip
Maintain Your Hard Drive.
Your hard disk drive is one of the most important parts of your PC. It's where all your system files, applications and user data is kept. Most people understand the issue of security, the importance of making regular backups of your user data as an insurance policy against hard drive crashes. Few people realise and appreciate the importance of having regular hard disk maintenance which is designed to keep it in good working order.
The ultimate way to revitalise and cleanse your PC is to wipe the hard drive, start from scratch and then reinstall the operating system. However, there is much you can do to avoid such a situation arising, simply by using utilities provided within the bundle of your Windows operating system.
Disk cleanup
The Disk Cleanup tool helps you free up space by searching your disk for unwanted files that you can safely delete. It can remove all of the following:
Temporary Internet files.
Files in the Recycle Bin.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use.
To launch Disk Cleanup via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be exampined and the amount of space you can potentially free up is calculated.
The results, showing the amount of space that can be recovered by deleting files that are not needed are then displayed on the Disk Cleanup tab.
Error Checking
Chkdsk.exe is a utility which verifies the logical integrity of a file system. In the event of the utility encountering logical inconsistencies in file system data, it will perform the necessary actions to repair the file system data. The same utility in earlier versions of Windows was called to as ScanDisk.
To Launch Chkdsk go to My Computer and right-click the hard disk you want to have checked. Then click Properties and select the Tools tab.
Click on Check Now.
A dialogue box showing the Check disk options is displayed.
Select the appropriate options and click Start.
You may get the following message.
If so click Yes and your computer will reboot and then perform the scan.
Since files are constantly being written, deleted and over written to the hard drive, files are likely to become fragmented and scattered all over the drive. The disk defragment tool takes these files and puts them in order by eliminating spaces between files.
To start the disk defragment tool go to Start > Programs > Accessories > System Tools > Disk Defragmenter
Then select the Tools tab and click Defragment Now.
It should now display the hard drives showing total capacity as well as the free space of the drive(s).
Now select the drive you want to defragment and click Analyse.
The drive is scanned and a visual representation of how it is currently fragmented is displayed.
Depending on the the results of the analysis, you will be advised as to whether or not the volume should be defragmented.
Even if it's not necessary, you can choose to Defragment anyway if you like.
The time it takes to defragment the hard drive is dependent on the size of the drive, how the fragmentation lies and how much free space it has.
As the drive defrags you can see how it is neatly repacking the files by looking at the bottem visual bar.
Once it is complete you will get the following message
You can choose to view the report which will show hard drive information such as free space, used space, cluster size and the free space as a percentage. Or you can just lick Close as the defragmentation is now complete.
Doing these checks frequently will prolong the lifespan of your hard drive and make sure it's running at maximum speed.
on Mar 06, 2011 | Computers & Internet
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Laptop shuts down begining dump of memory runs check disk
Your hard disk has developed errors.
This might be caused due to damaged files on your hard disk, or a program you recently installed which may have some errors.
If you recently installed a program, that does not work well with your computer, you might consider uninstalling it.
You should also consider performing a disk defragmentation to reorganize file on your computer.
To perform disk defragmentation, go to your "My Computer"
Select your Local Disk drive, then right click and select Properties.
Click on the "Tools" tab, then click on "Defragment Now"
After that, select the Local Disk C drive, then click on Defragment.
Thank you for using Fixya,
Kenneth
Feb 15, 2010 | IBM ThinkPad T30 2366 Notebook
My hard drive suddebly crash!!help
Why Disk Fragments a problem?
Any storage action on the magnetic disk like creating, deleting, moving, updating and copying files will lead to fragmentation and consequent performance loss. As time goes by, this accumulation of fragments on your hard disk becomes bigger and bigger. As the hard disk reads and merges these separate fragments every time you open a file, they will eventually cause problems such as system slowdowns, PC crashes, slow startup and shutdown, and will even shorten the life span of your hard drive. That is why defragmentation is so important for your entire computer system.
Advanced Defrag – The better and easier defrag solution!
You may find various defrag programs in the market, they may look the same, but many of them lack of ability to
effectively defrag all the MFT (Master File Table), they will automatically skip certain system files with extensions
such as DLL, INI, COM etc during the defragment thus left remnant fragments after each defragment action, it can
also easily get halted while defragging which is very user-unfriendly.
Advanced Defrag rectified all the cons above from these defragmenters, and the efficiency is even better. Its advanced
defragment arithmetic not only enables you to fast defrag, but also defrag completely and thoroughly. If you would
like to give your PC hard disk a completely care and experience the most efficient defrag technology, Advanced
Defrag is the perfect choice for you.
How it works?
Your hard disk controls a magnetic head which searches the areas where the parts of the required file are located,
reads the data and transfers these fragments to the disk cache or EMS memory. The time this takes is called the
average seek time. The average seek time of most hard drives is less than 9.5 millisecond. The Advanced Defrag
program is able to collect the various fragments of each file and store them very quickly into contiguous space on
the hard disk which greatly reduces the seek time of the magnetic head. Better file reading and writing speed is
provided as a result. It does make a difference if you have got used to work and play with a fast and smooth system.
It also helps to prevent premature hard drive problems and retrieve the data in the event of a drive crash.
Download Advanced Defra :http://www.versionhunter.com/windows/System/System_Miscellaneous/advanced-defrag.html
Dec 23, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Tip
How to Perform a Defragmentation of your Hard drive, to increase performance!!!
When you install a program on to your computer's hard drive it just simply does so in the quickest way possible. Meaning it will install a program in the first available space that it can find, usually many different places, therefore resulting in what is known as fragments.
These fragments are often far appart causing your computer to become slugish as it has to find the fragments that it needs, to perform the task at hand.
You can therefore make your computer more responsive by arranging these fragments into contiguous pieces of information. In other words all information relating to a program is together in one piece making it quicker to read by your computer system.
This is done with the help of a program called Disk Defragmenter.
Follow these steps;
1.)Double Click My Computer
2.)Right Click the hard drive that is your system drive, usually drive C:
3.)Select Properties
4.)Select the Tools Tab on the top of the box.
5.)Under the Defragmentation heading click Defragment Now...
6.)Disk Defragmenter Now appears.
7.)Select the system disk again usually drive C: (The one with Windows installed on it.)
8.)Now click the Defragment button.
It will take a number of hours to complete, so only perform this when you have the time for it to finish.
The bigger your hard drive the longer it will take.
The benifit of this session is that it makes the computer operate more effieciently and will become more responsive.
The Disk Defragmenter is performed at about once a month, to maintain a good system.
Enjoy the extra performance!
damnor01
on Jan 16, 2011 | Computers & Internet
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
MY PC IS TO SLOW WHAT CAN I DO TO FIX IT.
  • HI
  • YOU JUST CAREFULLY FOLLOW THE STEPS
  • Step 1 Delete duplicate or unneeded files. The operating system of a computer uses the hard drivemag-glass_10x10.gif as temporary storage as it performs tasks. This is called the page file, and the more space the operating system has to use as the page file, the faster it can perform. By removing old programs and old or unwanted files, you give the operating system a chance to run faster.
  • Step 2 Defragment your hard drive. When you save files to your hard drive, they are not all stored in the same place. Instead, they are stored all over the hard drive in file fragments. This means that, when you go to access that file on your computer, the operating systemmag-glass_10x10.gif has to look all over the hard drive for all the fragments of that file. Defragmentation is a process that takes all of the fragments of those files and moves them around on the hard drive to put them all in the same place. This means that files are no longer scattered on the hard drive and are much easier to locate, making them much faster to access.To defragment your hard drive, go to your "Start" menu, then "All Programs," then "Accessories," then "System Tools," then "Disk Defragmentor." Then click your hard drive and click "Defragment." Do this before you go to bed, as it may take a few hours if it has not been done recently.
  • Step 3 Use antivirus and spyware scanners. Viruses and spyware can slow down a computer by running processes in the background and using up system resources. Having an antivirus program can prevent these types of malicious software from getting onto your computer in the first place. Scanning with a spyware scanner can eliminate software that was installed secretly with other programs. AVG antivirus and Avast antivirus are both popular, well-reviewed antivirus programs that can be downloaded for free for home use. Ad-aware is a likewise popular and well-reviewed spyware removal program that is also available for free. (See Resources.)
  • Step 4 Get more RAM. RAM stands for "random access memory"--the memory available for programs to use. The more of this you have, the faster programs can run, and the more programs can be run at the same time. RAM is a series of chips that have been manufactured together in a thin stick. Sticks of RAM are located on the motherboard in slots and are easy to replace, upgrade or add to. Since installing RAM only involves snapping a stick into a slot, and since it gives a boost to everything you can do on your computer, upgrading your RAM is widely considered the easiest and cheapest thing you can do to make your computer run faster. Also, if you don't feel comfortable installing something in your computer yourself, most vendors will offer to install it for you for a small fee
  • I HOPE YOU SUCCESSFULLY DO IT....
    PLEASE RATE ME
    THANK YOU
    Sep 20, 2009 | Acoustic Research HDMI SWITCHER AR-HD21...
    To slow
    Computer slowdowns have several factors.
    How much memory do you have?
    If its 256 or below, try adding or upgrading it to 512 mb or more. Having insufficient memory causes your computer to take some space of your hard disk as a substitute, which is a lot slower than the memory ram.
    Also check how much space is available on your hard disk. About 15% of the hard disk space must be freed to prevent slowdown.
    Use the Disk Cleanup tool to clean some unneeded files. Go to My Computer, then right-click the drive you want to clean up, then click Properties, and click Disk Cleanup.
    Try also to defrag your files to lessen the time for the access arm of your hard disk to search/read a file. To defrag your hard disk (or other storage device), go to My Computer, then right-click the drive you want to defrag, click on Properties, then tools, and click Deframent now. Analyze first so you will know if you should defrag the volume, then defrag if necessary. Do this every month to prevent too much fragmentation of files.
    Scan for virus and spyware, becuase most of them take hard disk space, memory and have high CPU usage, thus making your system slow even there is no program running. For free anti virus, try AVG. For anti-spyware, try SpyBot S&D.
    Also make sure that your computer is properly ventilated. Heat could also limit the performance of your computer.
    Nov 16, 2007 | Microsoft Windows XP Professional With...
    Tip
    Speeding up a computer by Defragmenting Hard Drive
    Is your computer running slow? Have you tried running anti-virus, anti-spyware, and anti-malware software to speed it up, but to no avail?
    Perhaps cleaning up your hard drive could help. This tip will explain, in step by step instructions, how to defragment your hard drive.
    To Defragment your hard drive:
    1) Go to My Computer.
    2) Right click on your C drive.
    3) Click Properties.
    4) Click the "Tools" tab at the top.
    5) Click "Defragment now..." in the middle of the window.
    6) In the window that pops up click "Defragment disk"
    Defragmenting your disk physically moves files that are similar or
    fragmented into an area that will more efficiently use your space.
    5) The Disk Defragmentor will analyze your hard disk.
    6) After analyzing it will move and defragment the information appropriately.
    Disk Defragmentation is complete. You should see noticable improvements in your computer's speed and preformance.
    on Dec 21, 2009 | Computers & Internet
    Dell Dimension 8200 PC Desktop Logo
    Alun Cox
