Question about Ecoquest Flair Air Purifier
The motor speeds up and slows down - Ecoquest Flair Air Purifier
  • 80 Answers
If the motor has not been oiled in some time, it may speed up and slow down. Email to miller@healthyti.com and ask for supplemental cleaning instructions. They are free and include oiling instructions.
Posted on Dec 28, 2009
My Brookstone PureIon Advanced air filter is stuck in TURBO mode and I cannot get it to slow down! how do I UN-stick it?
Sounds like the control is damaged. You could try calling Brookstone service and see what they say (they have a one-year warranty). Number is 1-800-292-9819.
Aug 12, 2016 | Brookstone Air Purifiers
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
Oreck SL will not work on medium setting
Either your switch is not making a contact internally or the wire that runs from the motor to the switch is loose or not connected, or that speed is burned out on the motor. Those motors have a separate wire for each speed, so it's either not getting power to the motor from the switch or the that speed setting is burned out on the motor its self. I would just work around it and use the low or high setting until you can take it apart to test if the motor is getting power from the switch, if so then the motor is bad, usually the bearings go out on the motors before the wiring does. Unless your motor was on medium and was stopped for a long period and overheated that setting which will melt the wires and cause it to not work. They have a safety switch on the motors now to keep this from happening.
Jan 12, 2015 | Oreck XL Professional Air Purifier
The Fan on my "Fresh
It could be getting clogged up. The lint screen has GOT to be kept clean or the machines fan will pull dust into the machine and it will cake on everything inside, including the fan(will make more sound while running) and can get into the bearings of the fan causing the problems you mention. It may also be a poor electrical connection. If you have ever OILED the motor...you'll have to clean it. It's not meant to have a lot of oil or grease on it.
Jun 10, 2011 | Ecoquest Fresh Air Air Purifier
We have model 11502 air purifier. Recently turned it on and it ran for a few minutes and then stopped. Motor sounded fine- no squealing, didn't slow down before it went off- just stopped like it was...
Yes there is a thermal cutoff that will shut the motor off for a period of time to protect it from getting to hot. If this is what happened after 20-30 mins. the motor should come back on and run again. If it does I would try to clean motor as best I could using a soft brush, vacumn, and blow out with air if possible. Clean fan of f as best you can to help motor run cooler.Hope this helps.Thank you
Jan 05, 2011 | Honeywell Air Purifiers
I have an Oreck air purifier model (air 4000). The power light is on but the fan will not turn unless I put it on high speed and manually push the fan to give it a jump start for it to start running but...
I tried that solution and it did not work due to the worn bushing. I went on line to CSH incorporated and ordered #534 Open Ventilation Fan & Blower Duty motor. The motor is a ball bearing motor rather than bushing, and is an exact replacement for the Fasco motor on the original. The repair is easy and a cheap repair at cost of about $67 dollars for the motor plus shipping. The unit now works great again.
Robert
Oct 30, 2009 | Oreck Console Air Purifier
Clean fan area
NOTE:It is easier to remove the motor when the upper housing is still sitting on top of the lower housing unit.
  1. Turn the power off by unplugging the unit.
  2. Next to the speed directions buttons there are thumb tabs. Press the thumb tabs so that they pop up and unlock the upper housing flaps. a tumb tab on
  3. The four flaps should then drop down like the peddles of a flower.
  4. Grab the center of the motor and lift straight up, be careful when pulling the power chord.
  5. The motor, fan and gear assembly should not be seperated from the rest of the unit.
This will let you clean with vinegar and water.
Great product. Germany design at its best
Oct 30, 2008 | Venta - Airwasher LW44 Air Purifier
Fan motor changes speeds on its own.
The control component or the control circuit for the fan can be causing the speed variation, or the bearings on the thing can be wearing (or contaminated) with the same result. If you can make a test bench, look (feel with a test pad, really) for drive transistors that get hotter than they should or an inconstant power resistor or shunt.
Apr 04, 2008 | Alpine Air XL-15 Air Purifier
How to remove the fan blade ?
080204 FixUp EQ air blog remarks
To remove fan blade you need to obtain a thin strong probe, such as a Scratch Awl for wood, that will fit without binding, into the cruciform spaces around the plastic collar. Gently insert into space of plastic collar and lever against the spring metal retaining clamp; getting started may require a bit of force, so be careful to adjust and gauge your efforts. The process is to move clamp in small increments, one side then the other, up the collar until clamp is free to remove.
The collar will still be tight, so if you can form your hands into a gear puller form with your finger tips between the fan blades under to the solid portion of the fan ring, pushing thumbs against the Spindle and lifting in as quick a jerk as you can manage to get it moving. Once moving it should be removed easily enough.
The electric motors have two bearing surfaces, one front one back. Both need to be addressed.
I like Breakfree or similar that acts like minor solvent / major lubricator with good thermal properties. The solvent aspect helps clean out unwanted particles and/or old dried lube. The new lubrication is heavy enough to hold up for at least a year; so yearly checking should be scheduled.
On other brands with heavier motors, I've tried greases when I've stripped down the motors even further. So far I've discovered a heavier lube can be hard on start up and need more time at slower speeds until unit warms up.
Something like WD40 is good for penetration and flushing, but IMO too light for sustained duty. There is a lot of spinning and heat over a year's time.
I just torn down a couple of F1's. They've been doing well for a couple of years. But with all air filters/ purifiers, they REQUIRE periodic maintenance. [Had my biggest laugh reading complaints about Oreck air filters; people NEVER cleaned them and complained when they failed.]
Yes, all these small electrical motors will eventually need lubrication, I recommend before 2 years, as one of mine had a frozen (lack of lube) motor in that time.
If you get into the back to try to get at the rear bearing, you may find that you might be considering a more thorough cleaning (I noticed a bit of corrosion). If you do and if that means taking more stuff apart to clean, be well advised of the time involved and the number of wires needing displacement, especially the electronic wire connectors at the front to the circuit board.
So, get a digital camera and take clear pictures (and check them!) Before and During take apart as well as a couple of paper notes about wire runs and placement. I have even used paint pens to letter/number info to the unit.
Feb 04, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest Flair Air Purifier Logo
82 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
