Question about Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf000g washing machine won't complete a cycle
  • Hotpoint Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinemy hotpoint wf000g washing machine won't complete  - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 02, 2010
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
I have a hotpoint WF000G washing machine serial number 412138041 i have washed all the cycle instructions off the front of the machine so i am no longer able to tell which cycle each letter on the dial...
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 17, 2011 | Washing Machines
Hi, I've got a hotpoint WF000G which wont rinse properly on a fast wash, still soap suds on the clothing and have to put it on a full rinse cycle to get rid of them. Have tried clearing the filter (which...
Use very little detergent (HE) on a fast wash, about half the amount you usually do and set the machine to heavy instead of nomal, if yours has the settings for water level.The heavy setting uses more water. If your model does not have the normal/heavy settings, wash only very small loads on the fast cycle so that there is more water for the cycle. Also, be sure you are rinsing in cold, since cold water dispurses suds. You should also be sure that your rubber seal is very clean. I use a cloth and plain hot water and clean the seal weekly. It can build up alot of detergent residue as well as mold, etc.
Dec 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi, do you supply spares as i need a new mod board for a hotpoint aquarius wf000g.. thank you.
You will have to go direct to Hotpoint, or a spares supplier to obtain a new board for your washer.
Oct 27, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Can a control module from an aquarius wf000g be swapped with one from an identical wf000g??
So long as they have the identical figures on the module, and the models of washers are the same then you can safely interchange modules
Mar 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Feb 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi - reference our washing machine WF000G - the energy save light is flashing along with the on/off button and the machine wont run its cycle - can u help?
Do a search on Google using 'diagnostics, hotpoint, flashing lights'. There must be a manual which will identify what this fault is
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WATER IS POURING OUT THE DISPENSER DRAW OF MY WF000G
Normally if you take the soap slide draw out,you will see a hole underneath where the slide draw was. It normally blocks up with undesolved soap. Clear the channel then retry.Or sometimes water pressure is to high and then tends to splash internally causing water to drip out. Also make sure the slide draw is cleaned properly..
Sep 21, 2009 | Washing Machines
Hi i had my washing machine repaired last week as the bearings had gone and it needed a new drum (luckily it is under warranty). Now 6 days later there is water coming from the bottom and the washing...
to find the leak take your lid off + the access panel on the back now turn it on if u still cant find the leak tip it backwards and have another look but it could be a fault theyve done by not sealing the 2 halves of the outer drum if thats the case they should come out to it straight away or get in touch with the trading standards because it has only just been done and it must be something theyve done if it wasnt leaking before
Dec 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
125 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
