Question about SanDisk Sansa e250 MP3 Player
Head phones problem
Every time i move the right one turns off and the left stays on what do i do
    Scholar:
  • 103 Answers
You have a weak connection somewhere, either a kink in the cable or a bad connection where the cable connects to the right earpiece. It sounds like they need replacing I'm afraid.
Posted on Jan 09, 2008
6ya staff
SOURCE:
Its not working right the head only moves a little and only half the face works
Did you buy it with the head off new or did you buy it used and the seller removed the head?
Nov 25, 2011 | Hasbro Fur Real Friends Smores Pony
I have a error with a tally 2440 - Park error / Head jam
when the printer is turned on, the head moves to its home position. normally go to left then right & stays at middle. by opening the top cover u will see HEAD. see what object obstructing the movement of head. try to lubricate the shaft where the head moves right-left.
Sep 13, 2011 | Office Equipment & Supplies
08,007.41:8472 It's a phaser 8400 i have no idea what to do..What could it be?
Your print head wiper blade is not moving properly.
The clutch that moves the wiper may be failing.
That blade is located between the drum and print head.
Printhead Wiper Alignment: Rotate the left and right idler gears until the Wiper is all the way to the bottom and the gears cannot be rotated further. Rotating the left and right gears together ensures that the wiper stays parallel and does not pop out of the belts. Now rotate the left idler gear a couple of teeth to raise the left side of the wiper to the top. Make sure that the left side of the wiper is a bit higher than the right side. Might have to try this procedure a couple of times, a couple of teeth at a time, to properly align the wiper.
Feb 08, 2010 | Xerox Phaser 8400 Laser Printer
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
Please help....printer cartridge needs to be changed. When I pull up the cover the print head case should move from right to left so it is accessible. That does not happen. It stays behind the shield. How...
Confirm that the carriage timing **** strip film is free from damage
or grease.
- Clean the carriage timing **** strip film (with ethanol and lint-free
paper).
- Replace the
- carriage timing **** strip film, or
- carriage unit.
Oct 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Canon i9950 printer head stays on the right hand side
Check if the traction belt is in tension, you may need to replace the traction belt or the motor.
Try moving the carriage on the rail, if it does not improve you need to take apart the printer and replace either the traction belt or the motor.
Oct 04, 2008 | Canon BubbleJet i9950 InkJet Photo Printer
Rear passenger door won't stay closed
the door latch is adjustable. loosen the bolts (possible torx head) and move it toward the outside of the car . move it a very small amount, retighten bolts and try closing door. repeat as needed
Aug 03, 2008 | 1997 Chevrolet Lumina
Head of mixer droops
I just fixed mine this moring!!
Solution:
1- Lift head. In the lifted position you will see the head of an adjusting screw. Turn it to the left say a half turn.
2- Lower head and see if it is still too low. If so, do it again.
I had to turn mine like two plus full turns.
I beleive it goes into a nylon insert so that the threads are cut as the screw is put in the first time. If the screw is too loose, it may be possible that over time the head could slowly drop because of vibration and the screw slowly moving inward again. If that happens, a new nylon insert may be needed (but that is a different story).
There is another screw that may be loose of the head moves too much right and left. I also had that issue. This screw will be seen if you lay the machine on its side and look up the shaft (pedestal) of the base (large empty area the head attaches to). You will see a small screw head (first item up the open part). That set screw holds the unit in position on the hinge pin to stop movement from right and left.
You will find a full service manual in pdf at:
http://www.mendingshed.com/kitaidparts.html
Hope this helps.
Ken
Jun 11, 2008 | KitchenAid KSM150PS Artisan Series Stand...
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
