Question about Kenmore Washing Machines
Kenmore Elite Oasis model # 110.27032603 code f 80
Kenmore Elite Oasis model # 110.27032603 was beeping for no reason and would not run all the way through a load, found a way to do a test and got fault code f 80
5 Suggested Answers
  • 1028 Answers
SOURCE: need diagnostic test for Kenmore
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Posted on Jun 22, 2008
SOURCE: i have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Posted on Mar 18, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore elite oasis F2 (and beeping _
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump. Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and make sure that the impeller moves freely. If any blades are broken or missing or if it won't move freely, the pump will have to be replaced. Hopefully, it is just clogged, but no matter how diligent we are, some items like coins, tacks, pens/pencils, or other hard items make it into the washer and some can end up at the pump and can damage the impeller or clog up the pump. Hope this helped and best wishes.
Posted on Sep 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis dryer has a CF code and continuously beeps. Running or not.
The CF error is a communication failure between the main computer and the touch panel...you may have a bad or weak connection or a bad computer..I wold recommend that you contact your local Sears and ask them about recalls, and for service should this happen again.
May 07, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I hadn't washed any laundry for a couple days and then my Kenmore Elite Oasis starting beeping in the middle of the night. My husband had to unplug it because it wouldn't stop. The next morning I did some...
According to the Whirlpool Cabrio (Sears Oasis) manual, this code indicates a "stuck key"
Keypad/User Interface Failure
F then 2 flashes when in:
• Diagnostics Test mode if a stuck key is detected.
• Standby mode if there is a user interface mismatch.
Following is the PDF of the manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Sep 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore oasis elite it beeps all the time and flashes F2
Mar 18, 2009 | Washing Machines
Washing Machines Logo
169 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
