Question about Garden
Craftsman gas blower primer button does not depress. Feels like gas line is plugged. It does start up, but stalls in 2-seconds. There is plent of gas in tank. How do you fix?
  • 203 Answers
Sounds to me like you need to disassemble the carburetor and clean it out. Probably a plugged passageway in there. Spray cleaner where the fuel line goes in and put the fuel line back on and try priming, see if that will get things flowing a bit better for youj.
Posted on Nov 15, 2009
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Primer bulb stays in when pressed
Primer is either bad or the lines are switched around on the bulb.
Sep 25, 2014 | Sears 25cc 2-Cycle Gas Blower/Vac
Primer bulb on craftsman stays stuck
Something is plugged up. If I had to guess it sounds as if the lines are on the bulb backwards.
Dec 23, 2013 | Craftsman 25cc 2-Cycle Gas Blower/Vac
I have two craftsman leaf blowers that will not start, have changed the plug, is there a coil I need to check?
With the plug removed but connected to the spark plug wire if you pull the cord do you get spark? If so try pouring a cap full of gas in the spark plug hole and reinstall the plug and wire and try to start it. If it starts and stalls then you are not getting gas thru the carburetor. Check the fuel filter in the tank. Also check all the fuel lines and the primer ball and see if they are cracked. Also check the carburetor to see if the choke is opening and closing.
Thanks for using FixYa
Aug 19, 2011 | Craftsman Garden
Craftsman leaf blower starts and then stalls
ckeck fuel filter fuel lines and fresh gas, then clean carb and or rebuild it, also check primer bulb for function hope this helps., check exhaust muffler screen for being plugged
Apr 15, 2011 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
