Question about Husqvarna Zero Turn Mower Z5426
Engine will not turn over
I have a Husqvarna Zero turn Mower Z4217. When I try to start it I get nothing but the battery is fully charged. If I jiggle the key when trying to start I get some clicking in 3 sets of boxes that are plugs and the engine doesn't even try to turn over.
  • 203 Answers
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Posted on Nov 15, 2009
  • Mac O
    Mac O May 26, 2014
    I just had it serviced 2 momonths ago, the message on the control box says change the oil now. And says 60 hours. Turn the key and nothikung happens. Break engagaged, sitting in seat, battery good, nutrew position, fuse good connection logo good.
  • lnbn1975 May 27, 2014
    Check the battery connections, both at the battery and where they connect to the machine. Even the ground cable where it connects to the mower frame.
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
When trying to start my husquavarna 4824 zero turn mower it does nothing starter does not engage and battery is ok
Check your blade ingage switch. Sometimes they stick. You can jump start it by jumping across the solenoid switch beside the engine. I sometimes have to engage and disengage my blade switch and it starts. Hope this helps.
Sep 30, 2013 | Husqvarna Garden
I have a gravley zero turn with a kawasaki 24 hp it wont start when i turn the key all you hear is 1 click down by the solenoid
Check the battery connections are clean and tight and that the battery is in good condition and fully charged. If you're not sure about the battery, use a fully charged car battery and a set of jump leads to test that the tractor will start OK.
Aug 19, 2013 | Husqvarna Garden
Have a husqvarna zero turn I have to jump starter from battery for it to start....Why ?
Take the battery to your local auto store and have charge it and then do a load test on it. If it fails then it is a bad battery.
Aug 15, 2013 | Husqvarna 54'' Package Deal Zero Turn...
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
When I turn key on I get nothing. No lights , no engine hours, no nothing.
If the battery is fully charged you most likely have a blown main fuse. If you can't find it send me the model of the mower and I will try to assist you. Regards Phil.
Apr 26, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Husqvarna Zero Turn Mower Z5426 Logo
1,536 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
