Question about Garden
My 18ph twin spins but only starts when I short one of plugs to ground. what is the problem?
  • 8,404 Answers
I don't know what to tell you to do to fix this but I am convinced there is a broken ground somewhere in your system. When you ground one of the spark plug wires, you complete the circuit to ground allowing the other to fire.
You are not real specific as to that kind of Lawn Trimmer or Edger this 18 HP twin engine is hooked to nor what kind of 18 HP engine this is: electric start or magnito fired.
Look for a broken ground somewhere in your ignition system please.
Thanks for your interest in FixYa.com
please vote
thanks
a
Posted on Nov 14, 2009
Harley davidson codes
Hi Anonymous, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
For a prime suspect please visit the website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 12, 2014 | 2001 Harley Davidson FXST Softail Standard
No spark from coil pack
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley... Good luck
Feb 09, 2014 | Harley Davidson Motorcycles
NOT GETTING A SPARK ON MY HARLEY ROAD KING
For a possible prime suspect please visit the website below and good luck.
Jan 04, 2014 | 2000 Harley Davidson FLHRCI Road King...
No spark firing
Hi Ralph, on twin cams the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
For a prime suspect please visit the website below and good luck.
Dec 04, 2013 | Harley Davidson FXDL Dyna Low Rider...
No spark
Hi David, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
May 28, 2013 | 2000 Harley Davidson FLSTC Heritage...
2003 harley davidson roadking, no spark...checked coil, ecm, crankshaft sensor..all checks out okay..can a bad oil pump cause no spark...?
Hi Anonymous, on twin cams the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
Feb 03, 2013 | Harley Davidson FLHRCI Road King Classic...
2003 Harley Davidson Deuce wont start, No spark
Hi Ray, on twin cams make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
Jun 11, 2012 | 2003 Harley Davidson FXSTDI Softail Deuce
1998 harley davidson has no spark
Hi Tommy, on twin cams the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
Nov 03, 2011 | 2000 Harley Davidson FLSTC Heritage...
No fire to spark olugs, sat up for 6 mos, drained
Remove the wire that runs between both coils and try it again.If it starts you have a bad diode wire or a short to ground in the wire or shutdown system.
Dec 02, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Hi, my harley doesnt fire until i release the starter button.
Take your battery out and take it somewhere to have it tested. It sounds like your battery voltage is dropping below 10 volts. I'm curious to know how you discovered that the plugs doesn't fire until you release the starter button. On most of the Twin Cam engines, the engine is equipped with a compression sensor and the plugs will not fire unless the engine has compression. In other words, you can't check for the spark plugs firing like you to do by taking the out and laying them on the cylinder heads.
To check for spark, leave you old plugs in the engine. Get another set of spark plugs and put them in the wires and ground them. Turn the ignition switch on and spin the engine. Check to see if the plugs are firing. I made up a set of "test plugs" that have a short "ground strap" on them with alligator clips to ground them with.
Oct 07, 2009 | 2000 Harley Davidson FXSTS Springer...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
