Question about Acer Aspire 5920-6727 Notebook
Where is the power reset on my Acer Aspire 5920?
    Master:
  • Acer Master
  • 956 Answers
Reset button on acer aspire 5920 » Gadgets Manual
All you have to do future, enter question or specs in to google search, wealth of info to surf.
Happy surfing.
Posted on Nov 14, 2009
PABLOCSA
  • 1124 Answers
SOURCE: LCD replacement cost for ACER ASPIRE 5920
You will find prices here:
http://www.google.com/products?hl=en&q=acer+aspire+lcd+replacement&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=5&ct=title
Posted on Nov 19, 2008
  • 111 Answers
SOURCE: Acer Aspire 5920 realtek sound driver
http://support.acer-euro.com/drivers/notebook/as_5920.html
Select your operating system
Check your OS by right clicking on my computer and go to properties
It should be up the top e.g. Microsoft XP Professional
You might be selecting Vista 32 instead of 64
Hope this helped you out
Blazamane.
Posted on Jan 07, 2009
  • 489 Answers
SOURCE: acer 5920 keyboard setup
there is a software that launch menager. the program controls the keys you talked bout. you need to remove LAUNCh MENAGER.
Posted on May 30, 2009
babes_ganda0
  • 381 Answers
SOURCE: acer aspire 5920- camera not found
update the driver installer or download the driver web cam
Posted on Jun 25, 2009
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
Factory reset for acer 5920
Power on and press ALT + F10 to initiate the factory reset
NOTE : ALL DATA WILL BE LOST POST FACTORY RESET - BACK UP DATA AND THEN PROCEED
Oct 18, 2013 | Acer Aspire 5920 Crystal Eye Web Camera w/...
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
No power and the adaptor etc. is working okay
if the battery is old it may need to be replaced
have the voltage checked on that first
Jul 30, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not power on at all. The
Just to make sure:
1. With battery alone in notebook, and no power cable, do you get power?
2. With the battery taken out, and power cable plugged in, you do get power?
IF YES to the above two questions
... and u can get power using the power cable but not using the battery, then your battery is dead and u need a new one.
Mar 16, 2010 | Acer Aspire 5920-6727 Notebook
My acer aspire 5920 will not power on!
Hi
Thanks for using FixYa. You will need to reset the Laptop if it is not starting up. Follow the procedure as under to reset it---
Remove all connections to and from the laptop. Now remove the battery and press and hold the power on button for 2 minutes. Release the power on button. Slip in the battery pack. Plug in the power to the laptop and to the wall. Please do not plug in any other devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5920 factory reset
Then you need the Windows OS disc and drivers. You should've done a backup disc when you first got it.
Oct 03, 2009 | Acer Computers & Internet
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Crystal eye web cam not found on aspire 5920
Acer aspire has inbuilt web camera and therefore will work only if the correct drivers are installed. Please uninstall the drivers first from control/panel/add remove programs. Next reboot the system and then go ahead with the installation.
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
Thank You for using Fixya.com
Jul 26, 2009 | Acer Aspire 5920-6727 Notebook
DRIVER SET OF ACER-ASPIRE 5920
Download it here http://support.acer-euro.com/drivers/notebook/as_5920.html
Mar 22, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920-6727 Notebook Logo
939 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
