Question about Alpine CDA-9825 CD Player
Having trouble wiring a cda-9825 into my 94 honda accord any help would be great maybe a wiring diagram if there is such a thing out there for my situation.
Hi, Mike here, I have a 99 Honda Accord that im
read it your self (and you need more that that if not swapping all EFI and harness for same)
http://justgivemethedamnmanual.com/honda/honda-accord-owners-manuals/
Sep 21, 2013 | 1999 Honda Accord
I need the Airbag Wiring Diagram for a 1995 Honda Accord
helm has a great factory service manual selection, also you can probably get lucky and find one in a google search or maybe even on here. search "1995 accord service manual" i remember seeing them free for download or pdf view online. I know i seen alot more for earlier and later accords than my '99 when i was searching yesterday. good luck
Apr 19, 2013 | Honda Accord Cars & Trucks
Transmission wiring 2000 accord
can you follow the wire? does it come out of the harness and connect to the trans? automatic trans.? maybe old custom stereo or alarm wiring? i have the service manual and wiring diagram for 1998-2002. I have a '99.
Apr 18, 2013 | 2000 Honda Accord
Not finding FAS wirin on diagram.
Here ya go, maybe this will help.
Jun 02, 2012 | 1993 Honda Accord
MY 98 honda accord ac fuse keeps blowing. What's making it blow the fuse?
hey there,
it may simply be a bad body / loom earth or a chafed wire making contact with the bodyork. You never know, maybe its as simple as an underpowered fuse being used mistakenly. You`ll need to trace the wires directly or by using wiring diagrams for your vehicle.
Apr 30, 2011 | 1998 Honda Accord
Alpine 9887 displays INTERRUPT in 1998 Honda Accord EX
i think its the wires mate.
if you wnt to try something Discconect the battery of the car. let it 10 minutes and then plug it again. if it not work
the problems are the wires.
Check on the web for the distribution of the colors and wires from ur stereo and from the car.
cheers hope that help
Apr 25, 2010 | Alpine CDA-9887 CD Player
1991 HONDA ACCORD 178000 MILES RUNS GREAT LOOKS GOOD. wILL NOT COME OUT OF SPORTS MODE AND CHECK ENGIEN LIGHT WILL NOT GO OFF.. CAN YOU HELP
maybe computer under the passenger side floor board. If the sport light is flashing, then it could be the speed sensor. This link can show you how to check the check engine light on this car: http://troublecodes.net/honda/ You need to find the blue plug and insert a jumper wire, then you need to count the blinks in the led lights, and then compare it to the trouble codes. Carefully pay attention to the blinks, some will be short and others long. Long I think are 10s and shorts are ones. Once you get the code, then scroll to the bottom of the page and you will see the OBD1 codes, that is the one you need. Hope this helps somebody.
Dec 10, 2008 | 1991 Honda Accord
1992 honda accord spark plugs and wire
chilton or haynes manual will give you all this and every thing else you need for your vehicle
Aug 10, 2008 | 1992 Honda Accord
Alpine CDA-9825 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
