Question about Freezers
Chest Freezer not freezing
I have a Frigidaire chest freezer, model FFC15C2AW0, that isn't freezing the items in the bottom of the freezer. HELP!!!
  • 288 Answers
Check the temp dial. and set to a lower temp. *be mindful of the surrounding temp of the freezer. it will not work properly if it is in 125 degree surrounding air. * check the coils on the freezer and make sure that they are clean. this allows for proper heat transfer from the inside of the box to the outside air. also check to see if the blower is running. * Check to see if there are signs of oil around the freezer, if so contact a service tech
Posted on Nov 15, 2009
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
My ignis chest freezer isn't freezing anymore even
your cooling system matchine facced this problem.
Mar 20, 2013 | Freezers
We just bought a chest freezer and the suction is so tight can't open the lid .What do we need to do.
Most likely it isn't the suction but moisture on your seal freezing to the frame. Suggest a putty knife with a hair dryer blowing hot air on the blade and working it around the seal.
Aug 03, 2011 | Frigidaire 5 cu. ft. / 142 liter Chest...
My chest freeze just stopped working. Have checked
Your start relay or overload relay must have gone out. What is the model number of your unit?
Jul 30, 2011 | Frigidaire Freezers
Just got a used 5.0 frigidaire chest freezer and noticed that it is starting to frost at the top but water is starting to pool at the bottom. any help would be appreciated
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Mar 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
May 02, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
How to unfreeze the deep freeze, and which of the two type is more reliable,.,., tc tnx and god bless
There are numerous methods to defrost freezers, from placing buckets of hot water inside to using hair blowers. I like to unplug freezer, unload freezer, use a plastic putty knife to scrape excess frost off walls if in a bit of a hurry, and to let it just thaw out, using the drain port in the bottom of the freezer, hooked up to the garden hose adapter that came with the freezer to run the water to a drain.
The chest freezers are a bit more reliable than an upright (in my opinion) and are more energy efficient, but do make it harder to find and organize items in the freezer. FYI: Virtually any brand name freezer on the market in the US was built by either Frigidaire in St. Cloud, MN, W.C. Woods Co., from Canada, or Haier Co. in China.
Mar 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer not freezing!
try plugging the electric cord into a receptical
Feb 18, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Freezers Logo
178 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
