Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate freeagent external harddrive
I have a macbook OX 10.4.11 and when the hard drive is connected and i drag and drop items, it says it cannot 'could not be moved because freeagent cannot be modified'.  please help me on what i need to do!
    Sergeant:
    Champion:
  • 317 Answers
In any Mac OS System/Computer It cannot and will not write files to a NTFS Drive, but it will read.  The easiest solution for this is to search google for a program called "macfuse" this should fix the problem :)
Posted on Jan 09, 2008
6ya staff
SOURCE:
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
My Seagate FreeAgent Go250GB become write protected for Macbook, but works fine on windows laptop. How can I fix this issue?
It's probably formatted to the wrong filesystem; Macs prefer HFS+, Windows prefers NTFS, but they both can read and write FAT32. I'd recommend using the Mac's Disk Utility application to reformat the drive to be FAT 32 (but be careful, this will erase the external hard drive, so back up first!)
Apr 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I want to delete some folders previously backed up on my Seagate 100 GB USB External Drive. When I drag the items to my Trash (MacBook Pro) the next time I look into the Seagate, the files are there. How...
At the moment you're just copying them to you trash bin.
Access the requisite file/folder on your external drive, RMB click, should give you a drop down menu. Choose the Delete or Move to trash option.
Alternatively, click on (highlight) the file then click on file at the top of your browser window and select delete from the drop down menu.
Oct 21, 2010 | Seagate (ST9100801U2-RK) (9W3638556) 100...
My computer does not see my external hard dive
Go to this webpage (Seagate) http://www.seagate.com/www/en-us/support/downloads/ and choose from the SeaTools and FreeAgent Drivers that are appropriate for your OS and particular model. Formatting the harddrive should not have caused this problem of not being connected, but it is possible there was a piece of software that communicated with the computer that was removed via the format.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to format my new seagate freeagent 500 gb with macbook?
Here is a link to Seagate that describes how to fromat your drive fro a Mac. GOOD LUCK!
Oct 14, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Female end of USB broken inside external hard drive
try opening it up, screw loose the connection with your usb (the whole component) and then directly plug it into your computer with the plug that goes into harddrive:)
Apr 03, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,[email protected]
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Hard Drive Dropped
Turn off your computer and then plug in the FreeAgent external drive. Then try turning your computer on, it should read.  If it doesn't I would go to the Seagate website for troubleshooting.
Jan 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Read only drive
Fixed it by partitioning the Drive and formatting the Partition to Mac
Mar 01, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
220 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
