Question about Porter Cable 14.4V Hamm Drill Kit
The motor is smelling hot and I see sparks when I release the trigger. Any maintenance needed?
  • 8,404 Answers
It gets hot because this is very hard work for a 14.4 volt drill. For that matter, it is hard work for any portable or small electric drill. The sparks you see during the stop procedure are likely an electric brake. If yours doesn't have a electric brake - it may be too late for maintenance :-(
Your drill would appreciate it if you would give it a rest when it gets hot ... this is not good for your drill.
I am sure others will have more to say about this, here is my 2 cents worth.
Thanks for your interest in FixYa.com
please vote
a
Posted on Nov 14, 2009
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
I have a 1997 Acura 3.5 RL and have been told my valve covers are leaking . I smell a burnt oil smell but see no smoke at all . The smell comes trough my vents sometimes when my air is on . Is this really...
Hi your valve cover gaskets need replacing .
The reason you smell oil burning is the residue of oil ,,that getting in to the spark plug recess holes .As the spark plugs get so hot , then the oil is burning off .The vapour is sucked in to your heater vants . I know i have just replaced mine,and now i have no smell ...
Dec 03, 2017 | Cars & Trucks
I have a paslode model IM250II 16 ga straight finish nailer that I bought used the gun fan and motor runs whin the trigger is pulled but it does not fire when the tip is pressed no pop no puff nothing I...
Fan running when trigger pressed is normal however to make it fire you need to press on the work probe first and the fan should start running, at this point the gas should be injected and pressing the trigger should create the spark to fire the gun, if all works as above but the gun won't fire check the gas, the metering valve on the can should have a yellow ring and when pressing the can nozzle on a hard surface, gas should be released, if not the can either has (a) insufficient gas, (b) the nozzle is not correctly fitted (c) the metering valve is faulty, if the can emits gas the gun will need to be checked for spark and the seals will need checking
Aug 21, 2013 | Tools & Hardware - Others
Dewalt 25501k powerloss
it need a grease and o'ring maintenance
you need dewalt grease 870889-03 or rotary hammer grease
Sep 27, 2012 | Dewalt Drills
Model number WDSR2080G3WW. GE Top Loading Washing machine will not spin. It fills, agitates and drains but does not spin. Lid switch engages, motor tries to start the spin it won't spin, so the motor...
The reason for the hot smell must be investigated. If it is the motor that is getting hot it won't be a new motor for very long. The hot smell might be coming from a drive belt or a clutch and there could be a brake mechanism that is binding or not fully releasing.
Clearly the next step is to closely observe the operation of the mechanical parts...
Sep 15, 2017 | Washing Machines
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
18v dewalt battery gives off burning smell
18v is one of the newer models, correct? And the drill is new? If so there will be some smell as the motor breaks in. The srmsture is varnished as well as the windind for the commutator. The first few times it get s warm/warm from a heavy load, You will smell it. I would say there is nothing wrong at this point.Do not overload the motor and avoid drilling at low speeds. Use the variable trigger at low speed only for starting a hole. If you are driving screws start the screw,then full trigger driving it in. Good Luck, Ned
Nov 06, 2009 | Drills
Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Oct 16, 2009 | Vacuums
I have a 2550 poulan and it use to start on one pull but now takes a while and will only run until it gets hot and sometimes kills after releasing trigger
Yea I used to start that way to, but after time we all need proper maintenance try your filters & a new plug might help.
Apr 23, 2009 | Garden
Porter Cable 14.4V Hamm Drill Kit Logo
436 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
