Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher& Paykel Double dish drawer dd603 fault code f1, what do we do?! Where is the flood switch?
  • 3 more comments
  • muffin1010 Feb 03, 2008
    how do I get the bottom drawer out?
  • screwhead Feb 04, 2008
    All day and a few evenings for this installation, and I flood it on the second load...
    Where is the switch located under the bottom drawer? Is it visible or under a (white) cover? Please be more specific. Anything special to resetting it?
    Thanks tons!
  • Anonymous Aug 11, 2008
    F1 code and tool symbol flashing. Both drawers constantly running.
    Fixed by drying out sensor under bottom drawer. Many thanks to helpers
  • Anonymous Mar 17, 2014
    My fisher and paykel dish washer is full of ants
  • Anonymous Mar 23, 2014
    code 164 fisher paykel washing machine
  • 3 Answers
Hi Guys,
Our dishwasher was bone dry underneath yet we had F1 error on the top drawer only. Found the "flood switch" was dry, but the terminals for one of the drawers were a little dodgy; probably due to the mouse living in our dishdrawer - found plenty of it's evidence left behind. Removed the terminals, cleaned the contacts, re-fitted the terminals - all working OK
Cheers, Kiwi
Posted on Jul 26, 2008
Unplug power, turn off water. Remove lower drawer as shown in installation book; can be found online too. Mop up as best as you can with a sponge, place a fan pointing into the cavity and allow it to dry the interior, mine took an hour or so. Reassemble and restore power/water, and it should reset the fault. Be sure to resolve whatever issue caused the flood, mine was hand soap in the rinse agent reservoir, caused lots of bubbles and overflow. Flushed that as well as possible and mopped up the suds, ran 3 rinse cycles and a Normal wash with no detergent. Everything is A-OK for now...
Posted on Feb 04, 2008
  • 125 Answers
Its under the bottom drawer dry out and re-assemble
Posted on Jan 12, 2008
My dish draw **** up with a service code f 1 , what does this mean
This can mean several things. If you have double drawer dishwasher then you need to confirm if you get the F1 message in both drawers or just one.
If both drawers then it is caused by water leakage and flood switch activiates. If only in one drawer then the power supply to the other drawer is blown.
For single unit drawer it means flood switch triggered.
Dec 26, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and paykel double drawer dishwasher flashes F1 fault code, whats wrong or how do i clear the code?
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Aug 29, 2010 | Fisher and Paykel (IWL12)
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Doulbe Draw model receiving an F1 error message.
F1 indicates flood switch has been activated. I wouldn't advise you attempt repair on these drawers- they really require an expert to disassemble (I worked for F+P for 10 years!!). Depending on which model you have (DD603 or DD601v2), repair varies. 603 has a small circuit board that acts as flood switch- located in base beneath drawer- requires drawer to be removed for access. 601v2 model has polystyrene float that acts as flood switch-leaks usually caused by split lid seal(tricky to access- drawer has to be removed) In either case, a leak has occurred and activated flood switch. These drawers are very sensitive to detergents (don't use tablets!!), and the way they are loaded.
Would suggest you get service technician to remedy F1 fault
Aug 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do i fix f1 fault code on fisher&paykel dd603 dish washer
Ah the F1 question... unplug the machine, you cannot clear this fault by pressing any buttons. What has happened is the flood switch had been activated, meaning there is water in the lower pan, under the lower drawer. You can try letting it dry-out for awhile but the cause of the flooding can be many things including bad lid lifts, a broken link support, a cracked drain line, too large of plates or someone put Dawn in it. Most likely your link support has broken and caused a dent in the lid which seals the drawer during washing. You need to have a Tech out to look at it; call F/P for someone authorized to fix it.
Jun 07, 2009 | Fisher DEIX2 Dryer
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Dish drawer by fisher and paykel DD603 FPZW
flooded unit please remove drawer abnd dry board also read some of my other post on this problem
Jul 19, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
852 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
