Question about Whirlpool LGR4634J Gas Dryer
Glow igniter shuts down when dryer calls for gas
We just bought this dryer used. It was natural, and I converted it to LP. It will run, glow igniter turns on, then shuts down when it calls for gas. Very noisy when that happens
    Novelist:
  • 108 Answers
The very noisy part is a little bit odd...
Usually the igniter glows, the flame sensor detects the glow and sends power to the valve coils, which open the gas valve. There are some differences in that setup depending on the brand, but that is basically it.
It could be that the igniter isn't glowing hot enough (doubtful) or that the flame sensor (the rectangle thing on the side of the burner tube) isn't working (also unlikely, but still possible) or that the gas coils aren't working. Gas coils are the most common problem to go wrong on gas dryers, but when they go, they usually work at first, and then start to fail.
Do you have a volt/ohm meter?
Posted on Jan 08, 2010
Oven shut off and won't re-light
defective glow bar or bad safty valve. But if the glow bar does not light at all, most likely it will be a bad glow bar
Jul 09, 2014 | Summit WNM4307KW 36" Freestanding Gas...
Ho to convert a frigidaire natural gas dryer to a lp gas dryer?
Kits should be available at Sears.com, need to be a certified technician to change it. Involves changing igniter, burner scoop, and adjusting air shutters.
Feb 22, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Broiler does not light....Put in new ignitor; still not working. Checked orfice to make sure its LP and not Natural gas. Its number is #56...Is this correct for LP?
The Jenn-Air Broiler LP broiler orifice is part number: AP4091112. A picture of the part is here: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-orifice--broiler--lp--item-number-ap4091112.aspx . (To me the number looks like 65 to me. The natural gas version is number 47.)
Check the current draw at the igniter. (The meter must be in series with the igniter. I know the bake igniter needs to be above 3.2A.) Other possible causes of the problem are a selector switch problem or the glow bar. (These are things to check if the oven works.)
I hope this helps.
Jul 30, 2011 | Jenn-Air PRG3601P Gas Kitchen Range
I bought a comfort glow vent-less space heater model # CJ18NL. It had a natural gas valve on it and the guy said I could put on a propane valve, which I did. It's not lighting. Is this model only good...
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Feb 19, 2010 | Desa International GWP20T GLOWARM Wall...
I bought a used 24 inch GE gas wall oven, changed it over from natural gas to lp and it will not ignite they glow red but no flame
Many times, unless you have the universal, the orficies have to be changed. From nat to LP. they do make a universal type.
Dec 15, 2009 | GE 24" Built-In Single Gas Wall Oven
Kenmore Model# 97284810 Natural gas not heating and gas was on. Do this have an automatic pilot or does it need to be lit?
There is a glow bar igniter located beside the gas valve. Remove the front panel to access the glow bar. Replace the glow bar.
Jun 07, 2009 | Kenmore Dryers
Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Jan 19, 2009 | Kenmore Dryers
Dryer won't heat
Hello tfulton1963,
The fact that it worked for 3 days and then failed suggests that it is probably something else. You may have a non-resttable thermal fuse that opened or the gas valve itself isn't functioning. Can you see the glow of the igniter when it starts? Are you sure the burner is getting gas from the inlet valve?
These are the basic components to investigate.. Let me know the outcome of these checks and we can get you going again if none of these work.. Regards
Oct 10, 2008 | Amana NDG7800AW Gas Dryer
SPEED QUEEN MODEL AGS68AWF-- I'VE CLEANED ALL VENTS. NOT GETTING HEAT.DRYER CYCLES BUT GAS DOES NOT TURN ON. I'VE OPENED BOTTOM ACCESS PANEL AND NOTE THAT THE IGNITER GLOWS AND CYCLES BUT GAS DOES NOT...
If the glow bar is cycling off and on the glow bar works and the black box on the side of the vent are working, Either there is no gas to the dryer, doubltful but something to check or, You need a gas valve.
I would check for gas first, do you have other gas appliances? and all are functioning properly? Check the gas line and make sure someone hasnt accidently turned off the gas. If it is none of these you need a gas valve.
Go to repairclinic.com or partselect.com with your Sp Q model number, or the part number off the gas valve, it could be a five digit 58**** or 51***** number. Get you best price. Im guessing 80 to 100 Amercian
When replacing the gas valve, unplug the dryer first, turn off the gas, remove the front panel, two screws lower front panel, you will need a crescent wrench for gas line of side and a 5/16 nut driver remove wires. Now remove the orfice from the old gas valve and make sure you install it on the new valve. Is this a Natural Gas or LP Gas dryer?, If it is LP make sure you make the conversion to LP. Ask if you have more questions on this.
install gas valve, tighten gas line turn gas on check for leaks! with a bubble solution, start dryer and make sure dryer works properly.
best of luck
T
Jul 10, 2008 | Dryers
Whirlpool LGR4634J Gas Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
