Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
Paper holder is not working
The MF5770 I just bought dumps paper EVERY TIME I use it. The storage bin is not working. I did extend it. But it still drops the printed papers onto the floor. Anyone else have this problem? I'm certain there is a fix because nobody would find this acceptable.
Should I return the printer?
Can you help?
Doug
  • Stefcote May 05, 2008
    i have the same problem. almost every sheet ends up on the floor.
I used a very thin plactic ruler. It was inserted on top of the built in extension and prevents the paper from over flowing.
Posted on Jul 29, 2008
Mf5770 Error paper jam and etc.
It sounds like a clutch needs replacing.
Oct 22, 2013 | Office Equipment & Supplies
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2ΒΌ-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
My MF5770 5-in-1 printer is demanding that I load A4-size paper. It refuses to print or to do anything other than scan without A4, even though I've always used 8.5X11 in. paper.
Make sure that you have the correct driver from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5770
Dec 08, 2010 | Canon imageCLASS MF5770 All-In-One Laser...
We can't get the paper to go into the machine?
Installing the Paper Roll
1. Lift the paper holder so that it extends behind the calculator.
2. Make sure the calculator is plugged into an easily accessible
electrical outlet near the calculator.
3. Move the POWER switch to ON.
4. Insert the end of the paper into the paper slot on the back of the
calculator as shown. To avoid paper jams, use quality bond paper.
5.While feeding the paper into the slot, press and hold up arrow.
Note: To prevent damaging the printer (which may void the warranty),
move the POWER switch to ON when operating the calculator without
paper.
Nov 27, 2010 | Texas Instruments TI-5045 SVC Calculator
I can't get the door open do empty the shredding
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
Aug 23, 2010 | Royal PX1000MX Shredder
Canon Image Class MF5770 paper feed issue
2 possibilities. Your Document Feeder separation rollers need to be cleaned. You can clean them with a cloth and glass cleaner. Look for an assembly that looks like this:
Just rotate and clean the tires and see if that helps.
There is also a separation pad assembly that you might have to replace if it is worn out. It looks like this:
Both of these parts can be ordered from Precisionroller.com
I am not affiliated with them in any way. Just use them from time to time for parts such as these.
Good Luck
Dec 02, 2009 | Office Equipment & Supplies
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Printer is loading paper at an angle, so everything prints at aangle to the right.
The paper holder is adjustable, so make sure you have it snug up against the edges of the paper.
Older paper is dryer (yes, less moisture content) and doesn't pick up as easily--try new paper.
Also, check the paper bin for dust or other obstructions...
Aug 04, 2009 | HP OfficeJet 7310 All-In-One InkJet...
MF5770 ck paper size- change paper size
Go to the queue of print documents and continue deleting them until you get a message that reads no more in the queue. That will clear the error and then you should be able to resend with the correct paper size.
In our case the correct paper size was selected and received this error.
Jun 01, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
Paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Mar 20, 2008 | Canon ImageClass MF5770 Laser Copier...
old marine
old marine
